Phoenix Wi-Fi and Network mounted drive
I have been playing around with most of the Phoenix E-Boards on my Phoenix H5 and added a WiFi module onto the Phoenix Blitter FPGA board using SPI. I know that won't be the best transfer rates but it's an experiment.
Fully loaded well this H5 board has:
  • Phoenix Shifter v5 TANG Edition
  • Phoenix BLUE as BLITTER
  • Phoenix TRUDIE - IDE
  • Phoenix FlashyClock - 4x ROM, 8MB ALT-RAM, RTC
  • S2 MIDI Module
Phoenix H5 with many E-boards.png (1013.11 KiB) Viewed 41 times
A little tour around the board - lots of flashy lights:
Ok let's get down to the Wi-Fi part. I added a BL616 module to the Blitter and use several IO pins to do an SPI interface to the BL616. Working with Claude I created a network driver and a the ability to mount a network SMB share. The below picture shows the mounted SMB share on my Mac as AtariShare.
AtariShare on my Mac.png (1.04 MiB) Viewed 10 times
In the following video shows the Phoenix Panel and Wi-Fi setup. It's already connected to my Wi-Fi. I also built in a TLS proxy so that browsers like CAB and high wire can load HTTPS pages and the TLS is done on the BL616 board.
In the Net Drive panel tab it shows the setup for my N: drive not mounted initially and when I do install drives it mounts and you can see the N: drive. GEMBench is run from the mounted drive. This makes it so easy to run or copy files from a PC / Mac to the ST.
Return to “PHOENIX ZONE”
