Page 7 of 34
Re: Sporniket's log on hardware stuff
Posted: 08 May 2021 18:00
by sporniket
This week I could capture the schematics around the MFP. I planned to put the serial port too, but this one is not just wiring to IO ports, there are specialized ICs and voltage regulation curcuitery. I also had to fix the previous subsheet, with a forgotten capacitor and the parallel port and wiring incorrectly labelled with "serial" everywhere ! :oops:
As usual, the git repository is up to date.
subsheet_202-U202 — PSG and Parallel IO.pdf
(54.46 KiB) Downloaded 174 times
subsheet_203-U203 — MFP 68901.pdf
(50.64 KiB) Downloaded 167 times
Posted: 13 May 2021 06:35
by sporniket
The RS-232 port and alternate voltage generation. The "-12V" is just a hunch given that it is for the RS-232 driver. In other words, "I have no idea what I'm doing".
subsheet_204-J204 — RS-232 IO.pdf
(47.72 KiB) Downloaded 166 times
subsheet_205-U204 U205 — G12V -12V -5V.pdf
(39.58 KiB) Downloaded 164 times
Anyway, the sheet #2 is done, next sheet is the DMA circuitry (DMA, WD1772 and ports).
As usual, the github repository is up to date.
Posted: 16 May 2021 21:25
by sporniket
Here is the converted schematics for the DMA IC. The original schematics is done with the DIP-40 version of chip, and my STE has the PLCC44 version. Thus, I looked at other schematics (the Mega STE and the STBooks) to also get the pinout of the plcc version. The schematics of the STBooks seems more complete to me, as the pin 30 is annotated as "TESTIN" and wired to ground, instead of being omitted in the schematics of the Mega STE.
Another thing, on my motherboard, I fail to find a second bypass capacitor, as the plcc version has 2 Vcc pins.
subsheet_300-U300 — DMA.pdf
(54.53 KiB) Downloaded 157 times
The git repository is up to date.
Posted: 21 May 2021 19:55
by sporniket
Next subsheet, the ACSI Port, and the associated buffer/line drivers ICs.
subsheet_301-J301 — ACSI Port.pdf
(52.35 KiB) Downloaded 159 times
Also, this week I received the 4Mb SIMMs for STE made by @exxos to upgrade from 512Kb RAM.
I had to push harder than expected to fully engage the SIMMs in the connector. Simply place and push is not enough.
Anyway, it was a success
Now that my STE has more than 512Kb RAM, I can finally run Gembench. (And yaart tested successfully too)
Posted: 24 May 2021 08:38
by sporniket
The FDD controller and ports. The subsheet is quite full. I also took time to finally put a licence note on the page layout descriptor.
subsheet_302.sch
(26.8 KiB) Downloaded 151 times
Posted: 24 May 2021 14:56
by sporniket
The generation of SCLK and CLK2 was quick to do, and that's the end of the sheet #3. Next sheet deals with the GSTMCU, the shifter, and the video circuitry, it won't be so quick to capture...
subsheet_303.sch
(3.82 KiB) Downloaded 155 times
Posted: 27 May 2021 08:22
by sporniket
I have just finished the GSTMCU. It fits the A4 page !!
subsheet_400.sch
(26.92 KiB) Downloaded 153 times
The github repository is up to date.
Posted: 29 May 2021 22:57
by sporniket
The shifter
subsheet_401.sch
(18.4 KiB) Downloaded 156 times
The git repo is up to date.
Posted: 31 May 2021 15:04
by sporniket
Hum, how embarassing. It seems that recently, I have attached the kicad subsheets instead of the pdf tracing... :oops:
subsheet_302-U301 — WD1772 and port.pdf
(111.08 KiB) Downloaded 160 times
subsheet_303-U303 — SCLK & CLK2 clocks.pdf
(50.36 KiB) Downloaded 152 times
subsheet_400-U400 — GSTMCU.pdf
(117.56 KiB) Downloaded 158 times
subsheet_401-U401 — GST Shifter.pdf
(84.22 KiB) Downloaded 159 times
Posted: 01 Jun 2021 21:15
by sporniket
Today I completed the Video Port. The github repository is up to date.
subsheet_402-J400 — Video Port.pdf
(92.35 KiB) Downloaded 184 times
