Page 1 of 2
H4D SILK SCREEN LAYER
Posted: 25 Oct 2019 18:17
Current high-res of the silk screen layer. Should help people "find" bits on the board easier.
(zipped high-res)
ssh4d.zip
(168.38 KiB) Downloaded 203 times
Re: H4D SILK SCREEN LAYER
Posted: 28 Oct 2019 15:25
by PaulJ
exxos wrote: 25 Oct 2019 18:17 Current high-res of the silk screen layer. Should help people "find" bits on the board easier.
Hi Exxos, been making up a mouser order for parts I'm missing and some extra's. Couple of questions.
1. c5,c6,c7 seem pretty weird to me. c5 and c6 are both labelled on the layout image.
What type of caps are these, why is there 6 locations for three caps, what does the + mean in the symbol center mean, and last but not least is the symbol by the ACIA's c9.
Thanks.. Paul
Posted: 28 Oct 2019 15:33
by PaulJ
Hmm after further examination it looks like surface mount caps. If so what is the package type?
Posted: 28 Oct 2019 16:11
PaulJ wrote: 28 Oct 2019 15:33 Hmm after further examination it looks like surface mount caps. If so what is the package type?
The mouser part number is in the BOM..
https://www.exxosforum.co.uk/forum/viewt ... 167#p26532
You can also see them in Icky's build guide which he started the other day...
https://www.exxosforum.co.uk/forum/viewt ... =73&t=2229
Posted: 28 Oct 2019 16:39
by Icky
exxos wrote: 28 Oct 2019 16:11
I am going to update the build guide later tonight with the other SMT circuit areas so will point out the caps as well.
Posted: 28 Oct 2019 17:04
by PaulJ
Icky wrote: 28 Oct 2019 16:39
viewtopic.php?f=78&t=2167#p26532
viewtopic.php?f=73&t=2229
Guess I'm just a dumb ass but ordering this SMT stuff is quite a pain. Thought a 1206 was a 1206 ff just like a 1/4 watt resister is a 1/4 resister no matter where you order it but now I run into this. Also the BOM doesn't contain much that cross references here in a USA Mouser web site.???? So I'm basically picking out parts based on what they are but with the SMT its a more difficult be cause I haven't ordered that much of it. So is a 1206 a 1206 or are us and eu parts different?
Posted: 28 Oct 2019 17:09
Does not mouser part numbers not work on the USA site then ?! I don't get why your searching for stuff when I list the codes anyway...
667-ERJ-8ENF75R0V
I get the same page up with mouser.co.uk or mouser.com (USA)
Posted: 28 Oct 2019 17:46
by PaulJ
I don't see those numbers on the BOM I downloaded awhile back. For me the only useful data is 100uf. Then looking at the board image to determine its SMT part. Like I pointed out earlier I guess I'm just challenged. :( :( :( :D
Posted: 28 Oct 2019 17:48
PaulJ wrote: 28 Oct 2019 17:46 I don't see those numbers on the BOM I downloaded awhile back. For me the only useful data is 100uf. Then looking at the board image to determine its SMT part. Like I pointed out earlier I guess I'm just challenged. :( :( :( :D
You seem to be missing a column...
Posted: 28 Oct 2019 17:49
by derkom
Maybe you didn't look far enough to the right? They're in column F. :)
