Page 1 of 10
Atarian Computing's Raven Build
Posted: 11 Sep 2025 05:53
by Atarian Computing
Finally, I will begin my journey. I am now committed, having ordered most of the parts. Still not ordered or found:
- CPU Rev 6 ordered from Amiga Webshop
- CPU Socket (can't find one) 223 socket from eBay. Need to remove 17 pins.
- Case (will run some examples for opinions later)
- PSU
- KBD/Mouse
- Monitor (I mean, I have many to use, but I'd like one specially for Raven)
Re: Atarian Computing's Raven Build
Posted: 11 Sep 2025 06:44
For a case, I'm leaning towards a Chieftec CI-02B-OP Pro Cube, which is local to me. Here's a review of it:
https://www.techpowerup.com/review/chie ... ci-02b-op/
Posted: 11 Sep 2025 10:36
by DoG
I have built one of the
DIY sockets but it was fiddly and took a while. But cheaper I guess. Otherwise you
can get ready made from here.
- PGA_68060.jpg (96.64 KiB) Viewed 1972 times
- PGA_68060_2.jpg (59.59 KiB) Viewed 1970 times
Posted: 11 Sep 2025 12:09
Thanks. Archi-TECH is out of stock. But I ordered a 223-pin socket, so I'll just have to remove 17 pins, which should be fine.
Posted: 16 Sep 2025 15:20
I'll mock it up so I don't cock it up.
- 20250913_155343518_preview.jpeg (350.9 KiB) Viewed 1918 times
Posted: 13 Oct 2025 06:41
I started building last weekend. Here is the result from day one with all topside SMD components in place, as well as the PGA socket.
- 20251012_085250160_preview.jpeg (426.17 KiB) Viewed 1808 times
Soldering the SMD ICs was surprisingly easy. The 1206 components were difficult for me. I always put too much solder. So it doesn't look factory. But actually, I fully embrace that. It is a home-built machine after all. If it looked factory-made, my friends would never believe I built it from scratch.
The pin extraction from the socket was straightforward. No dramas there.
Here is the result from yesterday. All topside components are in place. No dramas here.
- 20251012_142720566_preview.jpeg (473.48 KiB) Viewed 1808 times
What's left to build:
- 1. All the caps underside, a thorough cleanup, and inspection
I expect everything to be assembled this week. The best case is the Raven running before the weekend.
Posted: 14 Oct 2025 07:44
Mainboard is complete except for programming Nessi and building CKBD.
- DSC09324.jpg (559.17 KiB) Viewed 1746 times
Posted: 14 Oct 2025 11:21
I just flashed Nessi with Nessi.jed assuming it's the latest. Is it the right one though? Should I use 250714.jed? @agranlund
Posted: 14 Oct 2025 12:17
by agranlund
I'd go with the latest numbered one: 250714.jed
However, @PhilC mentioned some trouble using it and if that's the case you may want to try the one before instead.
250714 had some changes to make more brands of CF cards work and if this firmware is an issue then perhaps it should be reverted and more thoroughly tested.
(was using a Kingston card before which always worked and didn't notice CF compatibility issues until I wanted to test a DiskOnModule thing)
Posted: 14 Oct 2025 12:32
by agranlund
Atarian Computing wrote: 14 Oct 2025 07:44
That was very fast! :)
You may already know but just in case:
- remove jumper from J101
(else you'll have IRQ7 constantly being triggered. the header is in case you want to hook up an external NMI trigger button)
- move jumpers on J102, J104, J105 to the top two pins.
(1x mode is not well tested and compatibility is probably so-so)
- you can put a jumper on J203 based on how many frontpanel LED's you have.
(controls if disk activity is shown on a dedicated LED or shared with the Power LED)
