Page 1 of 1
Programing 6 Eproms with TOS image
Posted: 30 Aug 2025 08:38
by pe1goo
Hi,
I've an Atari 260ST and want to update the ROMS. I've a suitable tos bin image and want to program it into the 6 EPROMS. Is there a tool to split the image into 3 HI and LOW files so I can program the 32K*8 PROMS?
Re: Programing 6 Eproms with TOS image
Posted: 30 Aug 2025 08:49
by Steve
You can use Peter Putniks TOS splitter:
https://atari.8bitchip.info/astopensw.php
I use it under Hatari.
Posted: 30 Aug 2025 09:36
by pe1goo
Thanks,
I'll try this, fortunately I have hatari so it must be no problem.
Posted: 31 Aug 2025 09:50
Attached is an archive of the ROM splitting tools I've used including the 6 ROM set of TOS 1.04 UK.
They do work under Hatari, that is what I used to split them in the past. Use a GEMDOS drive set up to get them out of Hatari for burning.
I suspect your 260ST is very similar to my 520ST so 6x27C512 ROMs should work. Remove .txt from the end to use as a ZIP file, this is necessary since ZIP is not an allowed uploadable file type.
!Message from: Moderator
@rubber_jonnie, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
