Page 1 of 2
Exxos's H5C5B Build
Posted: 24 Feb 2025 14:44
This is the board as sold in the store currently.
NOTE - 2 resets switches may be included.. One is the wrong type (6 pins, not 3 pin) I couldn't be bothered to remove the 6 pins ones, so the correct 3 pin were just slotted inside the box..
The 2 oscillators & MFP are included. Most other parts can come from the store (sockets etc) and main chips, but I suggest using a old (broke) ST to use as donor chips etc
Let's get building :)
This is the minimal steps to get it booting rather than a complete assembly guide... Maybe someone else can do a more comprehensive guide..
Firstly fitting the two oscillators..
Re: Exxos's H5C5B Build
Posted: 24 Feb 2025 14:48
The reset switch has pi$$ed me off. As for some reason the holes are the wrong size for the switch frame :roll:
My only solution is to bend the front metal tab sideways and scratch a bit of the resist of the PCB to make a solder point.
The other back pin I did not bother with I just cut it off.
I also noticed that the left back pin could actually wear through the solder resist and short out on the track so I have bent that rear pin upwards to miss it and I will update the PCB files to correct that problem. That problem must of been there for a while and went unnoticed until just :roll:
I think the hole size thing might have happened because the holes were not part of the switch template actually just on the PCB.. I think at some point I moved all the holes to 0.3mm instead of 0.2mm (which involved a fair bit of re-routing as well) as larger holes will be stronger and can be a bit cheaper in some fab houses. Though the switch holes must have got "caught" in the resize :cry:
Also noticed the PLCC location dots on the silkscreen also seem to have fallen victim to the hole resizing :roll:
Posted: 24 Feb 2025 15:48
Bit more progress...
Posted: 24 Feb 2025 16:08
First power up - smell of burning :roll:
It seems the amp chip was soldered in upside down and it let the magic smoke out :roll:
Posted: 24 Feb 2025 16:09
TOS104 booted from floppy fine :)
Posted: 24 Feb 2025 16:11
NEW FEATURE - Built in TOS206 decoding.
To enabled it, solder the jumper pad as shown...
Move the ROM select jumper to the 104&206 decoding location.
Move the ROM bank select jumper (open for upper bank select)
Done :)
You can now just simply alter the ROM bank jumper to select TOS versions.
Not bad if there are only two relatively minor screw ups this time I guess :lol: :hide:
Posted: 24 Feb 2025 18:19
by stephen_usher
exxos wrote: 24 Feb 2025 16:08 First power up - smell of burning :roll:
Oops! Just this board or all of them? Is it obvious on the silkscreen which is pin 1?
At least it's booting otherwise! :-)
Posted: 24 Feb 2025 18:26
stephen_usher wrote: 24 Feb 2025 18:19 Oops! Just this board or all of them?
I assume all of them, I don't really fancy unpacking and repackaging the whole lot to find out :)
Posted: 24 Feb 2025 18:32
by stephen_usher
exxos wrote: 24 Feb 2025 18:26
OK, so there's a mandatory fix for all the purchasers to do... Either use hot air on the amp or let the magic smoke out.... their choice.
Posted: 24 Feb 2025 18:42
stephen_usher wrote: 24 Feb 2025 18:32 OK, so there's a mandatory fix for all the purchasers to do... Either use hot air on the amp or let the magic smoke out.... their choice.
Yep, nobody will read instructions anyway, so i will just put a sticker on it to warn people about it.
The problem is that chip is a Chinese one, I don't have any stock of them here :(
