Page 1 of 3
TOS206 Decoder MMU Plugin not working
Posted: 01 May 2024 17:04
by Emwee
Hi,
today I soldered my TOS 206 Decoder (MMU Plugin ->
https://www.exxosforum.co.uk/atari/store2/#0248 ) and the Mega ST Dual TOS PCB (
https://www.exxosforum.co.uk/atari/store2/#0008 ).
The Dual TOS board works, I've tried it without the Decoder and the Jumper set to TOS 1.04, system works as expected.
Then I plugged in the Decoder and my system just stays with a grey screen, nothing happens.
This is how it's soldered an placed top of the MMU:
- Decoder_01.jpg (726.4 KiB) Viewed 2583 times
- Decoder_02.jpg (767.92 KiB) Viewed 2583 times
- Decoder_03.jpg (715.92 KiB) Viewed 2583 times
- Decoder_04.jpg (728.5 KiB) Viewed 2583 times
- Decoder_05.jpg (747.41 KiB) Viewed 2583 times
What have I done wrong?
Many thanks,
Markus
Re: TOS206 Decoder MMU Plugin not working
Posted: 01 May 2024 17:09
It's supposed to plug over the GLUE..
Also you will need to cut the CE pin to the MB on the dualtos boad.
Posted: 01 May 2024 17:13
Now got me thinking
https://www.exxosforum.co.uk/forum/view ... 961#p94115
Clearly on the glue on the H5 but all my info says MMU :roll:
Posted: 01 May 2024 17:26
by Emwee
well, yes :D
Tried it over the GLUE, unscrewed the PSU and placed it a bis aside, also doesn't work - even if it would work : you'll never get the Mega ST put together again, because the GLUE is under the PSU and it all gets to high.
Posted: 01 May 2024 17:34
Did you cut the CE pin ?
Posted: 01 May 2024 17:37
by Emwee
Yes, it is removed.
Posted: 01 May 2024 19:26
Sounds to me like a bad contact in the socket area, how far in was the decoder pushed?
Posted: 01 May 2024 19:44
by Emwee
As far as it goes, I'd say complete.
Posted: 01 May 2024 22:51
I suggest fluxing the pins and reflowing them under a magnifier as a lot of the soldering doesn't look great. Also make sure you don't have any shorted pins.
In particular the highlighted pins as these are the important ones.
- Capture.PNG (80.03 KiB) Viewed 2517 times
I would also return your machine back to stock and make sure it still boots up before doing anything else! Inserting the plugin boards can result in bad connections on the MMU. The socket pins may need to be adjusted.
https://www.exxosforum.co.uk/forum/view ... 484#p16092
Posted: 02 May 2024 17:16
by Emwee
Returned to stock all works fine, will reflow the pins later.
But where goes it in? MMU? Or GLUE? :) If GLUE, then I'll give it a try, but it can't be used at the Mega ST.
