Page 1 of 1
Sharp X68000 Screen Prompt
Posted: 30 Sep 2023 23:47
by RetroTec
Hi does anyone know what this prompt means, trying to load space harrier, it starts loading and then stops with this message prompt
- sharp.JPG (40.46 KiB) Viewed 7001 times
Using a 1MB ACE X68000 with a Gotek attached using an .hfe disk image
Re: Sharp X68000 Screen Prompt
Posted: 01 Oct 2023 13:48
by Higgy
'Papago' is a really useful App (not sure if on Apple Store) it seems to have a better conversion for Japanese than say Google Translate.
Pretty sure I ran Space Harrier on 1mb as someone at a retro show commented about not having a chequered floor and that was when I had no memory upgrade.
Alot of issues are due to SRAM not being set/saved.
Load MasterDisk V2 and type switch.x if you have not done this already.
Memory should be set to 1mb, you need to press Escape then Save.
Posted: 01 Oct 2023 14:59
by RetroTec
Thanks again for the assistance, not yet used switch utility so will try that I forgot there is no bios like a normal pc its in sram settings, I have no backup battery yet got to solder in my nimh replacement, luckily I removed the original nicad just in time before it caused any damage
Posted: 05 Oct 2023 20:51
by Dlfrsilver
RetroTec wrote: 30 Sep 2023 23:47
sharp.JPGUsing a 1MB ACE X68000 with a Gotek attached using an .hfe disk image
This message indicates a program error with SR = $2700:PC = $00FF1B0A
Retry / Ignore / cancel
Posted: 05 Oct 2023 22:05
by HigashiJun
Dlfrsilver wrote: 05 Oct 2023 20:51
Precisely, it should read:
An address error has occurred (SR=$2700:PC=$00FF1B0A)
Cancel <A> Retry < > Ignore < > ?
8-)
