Page 1 of 6
Detecting Fake BluePills - BEWARE
Posted: 07 Aug 2023 16:30
@BrettRogersUK recently sent me his home built ACSI2STM device for testing, since it wasn't working on either his, or his Dad's STEs.
Looking at the docs, the ACSI2STM should show it's firmware version at boot if there is no SD card installed.
This one didn't, so I tested it with a program called Blinky (Attached, just change it from .TXT to .HEX). It's simple and blinks the LED, but it only works on genuine BluePills. (Source:
Detecting Fake BluePills)
It works on my 2 BluePills (A relief, I thought they might be fakes), but not on Bretts.
In addition, despite being marked the same as mine, as an STM32F103C8T6:
- PXL_20230807_145618719.jpg (512.21 KiB) Viewed 1921 times
ST-Link saw it like this:
- Brett_BluePill.jpg (26.45 KiB) Viewed 1921 times
But mine shows like this:
- My_BluePill.jpg (27.79 KiB) Viewed 1921 times
Which I believe may be the lesser STM32F103C6T6, or even a re-marked bad chip. That said, mine could also still be fakes, just better ones that pass the visual and Blinky tests.
So, I'm posting this just as a warning. Take care to be sure you're getting what you pay for.
Re: Detecting Fake BluePills - BEWARE
Posted: 07 Aug 2023 16:35
by PhilC
Thanks @rubber_jonnie I'll test mine later on
Posted: 07 Aug 2023 16:47
PhilC wrote: 07 Aug 2023 16:35
I'm not saying it's 100%, but along with the visual checks, it's definitely worth doing. Be interesting to see your device ID too.
Posted: 07 Aug 2023 17:11
by czietz
Though, if yours is marked STM32F103
C8 but claims to have 256 kiBytes of flash, that's questionable, too:
- stm32.png (675.23 KiB) Viewed 1903 times
Posted: 07 Aug 2023 17:13
by BrettRogersUK
Hi Jonathan,
I got THREE of those Blue Pill boards. Two of them identify as 0x410 chips (as you have one of them) and my other one here identifies with a code of 0x414 and passes the blinky test.
Chip markings on the blue pill
- chip markings
- PICT0001.jpg (169.73 KiB) Viewed 1903 times
Device detection in the stm32CubeProgrammer - 256kb memory
- STM32CubeProgrammer
- Screenshot from 2023-08-07 17-05-23.png (19.09 KiB) Viewed 1903 times
Passes blinky test as have got a flashing LED on PC13 however, it flashed without having the BOOT0 jumper set to programming mode.
Thanks for testing it though for me, I have got a known working ACSI2STM device by a guy called Masteries over on the atari-forum. It came from Spain today and I plugged it in and it worked strait away. no messing about. So, at least I know there isn't a problem with the ACSI side on my STE. It can turn into a rather expensive game of operation if not careful with these vintage machines. The blue pill on the Masteries version is marked as a C6T6A.
I know there are others that have built the device based on the github (
https://github.com/retro16/acsi2stm) and they have worked straight away without fault so it would appear that I have been extremely unlucky with my blue pill boards. I Have just noticed however that this one may also be a fake as they have printed on the silk screen next to the reset button 'RESRT' instead of reset :lol: :lol: :lol:
Thanks again,
Brett
Posted: 07 Aug 2023 17:29
by elterwater
Out of curiosity, is there a known trusted source of genuine blue pill boards here in the UK? I've fallen down the rabbit hole of Farnell and Mouser and can't find anything resembling the boards, just the chips themselves. Any pointers would be gratefully received please :)
Posted: 07 Aug 2023 17:59
by stephen_usher
It depend upon whether you want the STM or "compatible" ones. AZ-Delivery do one of those. I don't know if it's close enough though.
Posted: 07 Aug 2023 18:06
by BrettRogersUK
stephen_usher wrote: 07 Aug 2023 17:59
One of the boards I used for this was an AZ-Delivery one from Amazon. it was purchased in Jun 2022 with the intention of building the project straight away but life got in the way and I only got round to having a look at the project a few weeks ago.
Posted: 07 Aug 2023 18:30
czietz wrote: 07 Aug 2023 17:11
You're quite right, which is why I am not 100% convinced that mine are real, despite the blinky test passing.
Do you have a link to the data you posted, it would be really useful to have, thanks.
Posted: 07 Aug 2023 18:32
by Higgy
elterwater wrote: 07 Aug 2023 17:29
This is a UK based company. I've used them before, but not sure if I actually bought this device from them, i definitely bought the programmer from them:
https://hobbycomponents.com/st-micro-el ... ment-board
They even answer questions on their forum to assist.
