Page 1 of 2
Atari ST first model power port ?
Posted: 12 Jun 2023 21:14
by sporniket
Hello,
I am looking for data about the 7 pins, male, round power port of the Atari ST first model. It obviously is not a usual "DIN port".
Ideally a standard part datasheet with measurements for the footprint. (I already have measurement, but I would like it to know that it was a standard "pots" -parts on the shelf- of that time, and maybe still sold as NOS.)
Thanks in advance.
Re: Atari ST first model power port ?
Posted: 12 Jun 2023 21:16
by alexh
Posted: 13 Jun 2023 21:48
by sporniket
Posted: 13 Jun 2023 21:53
When I built my replacement PSU for my 520ST, I just used a female 7 pin plug I got off ebay and trimmed the plastic shroud back, works perfectly.
Posted: 13 Jun 2023 22:13
by sporniket
Thanks for the tip
@rubber_jonnie
Another source :
https://rudedogretros.co.uk/product/ata ... pcb-mount/
The photo of the back show a brand "Singatron"
Posted: 13 Jun 2023 22:27
If there was an actual date sheet I might be able to track the actual part down and possibly even obtain some :shrug:
I did buy a stack of chassis mount connectors many years ago with the intention of building a new ST power supply but that idea got abandoned.
Posted: 13 Jun 2023 22:28
Ahh, actually I think I misunderstood. You wanted the part that attaches to the mainboard, not the plug that fits into it, sorry, my mistake.
Posted: 13 Jun 2023 22:52
by sporniket
rubber_jonnie wrote: 13 Jun 2023 22:28
no problem, there was a usefull tip for a connected (pun obviously intended :D) problem
exxos wrote: 13 Jun 2023 22:27
The fact that it's called "DIN" like the usual DIN ports do not help... Either abusive use of "DIN" (because round and pin numbering and arrangement), or there is a spec number to know (like midi ports follows DIN 41524)
Posted: 13 Jun 2023 23:05
Posted: 13 Jun 2023 23:22
by coonsgm
Unread post by rubber_jonnie » Tue Jun 13, 2023 4:53 pm
This here. I did the same and used a meanwell RT PSU to connect to a female 8 pin plug (I couldn't find a 7 pin one and just connected the lines I needed to).
Works like a charm
