Page 1 of 1
Playing AmigaCD32 games on Amiga 4000/1200
Posted: 07 May 2023 12:05
by Rabanik
Hi,
is there a way to play CD32 games on Amiga 4000? The best from a virtual drive and CF card (BIN/CUE files) and mainly games with CD-DA tracks using of some IDE-fix '97 (a CD32 Emulator/ utility)? It seems there is a lot of issues in the way:
- Amiga 4000 has no Akiko chip for best compatibilty with CD32 probably for "hard coded" CD32 games
- Paula chip is not powerful to play both SFX + CD-DA tracks at once and it is "only" 24kHz while CD-DA tracks are at 44.1kHz
- there could be a higher requirements on a CPU speed and probably more RAM
Maybe the best way (instead of an emulator) could be using of a real CD drive. But for hearing of CD-DA tracks there will need to mix Paula's and CD's output together the best with a volume control of each output.
Or does exist and ODE for Amiga?
Or is there a possibility to add an SPDIF or I2S header for CD-DA for example on some incoming TF card? TF card could be powerful enough for the CD-DA job.
Thank you for some experiences.
Re: Playing AmigaCD32 games on Amiga 4000/1200
Posted: 07 May 2023 12:42
by terriblefire
Rabanik wrote: 07 May 2023 12:05 Hi,
There is allegedly some CD32 Emu software in IDEFix97 (on aminet) i think you need IDEFix97 though.
Of course games that need Akkiko will not work
Posted: 07 May 2023 14:43
by Rabanik
Is there a list of games which work only with Akkiko chip?
And what about of CD-DA? Is there a possibility to add an SPDIF header on some acceleraror board for CD-DA output? It could be theoretically possible with WHDload.
And when I ask thisway. I have CD32 and want to play CD32 games with CD-DA without of use of its real CD drive. Is that somehow possible?
Or does exist an ODE for CD32? Or can I replace CD drive with usual IDE CD drive? Does exist some controller/adapter?
Posted: 07 May 2023 14:47
by terriblefire
Rabanik wrote: 07 May 2023 14:43 Is there a list of games which work only with Akkiko chip?
There is CD32 version of WHDLoad. That might be your best bet.
There isnt an IDE alternative for the CD32 yet (that i am aware of anyways). I dont know about software emulation of CDDA
Posted: 07 May 2023 15:15
by Rabanik
Thank you for the answer.
And is there a possibility to add on some incoming Terrible Fire boards an SPDIF or I2S header for CD-DA? If on this board has an IDE controller for CF/SD cards it could also work as a emulated CD drive. At least for CD-DA. If some free resources are still the CPLD it could be possible. A combination of WHDLoad & TF would be solve the problem with missing CD-DA output.
