TF1230 boot issue coldstart
Posted: 26 Apr 2023 20:39
Hi,
I have an issue that shows upon coldstart with my TF1230.
When i coldstart the Amiga the powerled comes on and the harddisk-light is lit for about 15 seconds and then goes off and thats about whats happening. Black screen, no floppydrive-clicking. I have to reset the Amiga (Ctrl+A+A) several times before it starts to boot properly into workbench.
The machine is recapped erlier and this was no problem before i got the TF1230-card, the Amiga worked flawlessly. I have a new aftermarket PSU from Amigastore.eu.
It's just when coldbooting the problem shows, when i get it working it is very stable. No guru meditations. hangups or so. But on next coldboot powering on the Amiga, the same... i have to reset, reset, reset and after about 4-5 resets it finally boots.
I have a Indivision AGA MK3 flickerfixer
A CF2IDE-reader directly mounted on the IDE-connector of the Amiga motherboard, so no cable. With a 32 GB CF-card.
Kickstart ROM 3.2.2 (Hyperion) and Workbench 3.2.2.1
Tried to reseat the TF1230-card, clean connector with isoprop alcohol.
If i remove the TF1230-card, the Amiga boots on first try at coldstart.
Someone have any tips?
