Page 1 of 2
TF360 - Shapeshifter won't start
Posted: 06 Mar 2023 21:57
by OSH
Ok, I'm ran out ideas.
I have TF360, and I want to launch ShapeShifter. But I can't. Everything I see is a grey screen. Nothing is loaded. I'm using MuLib package and MuEVD - but it doesn't work. And in MULTISCAN Productivity mode is quite slow. And second question: why I can't use CD-ROM? When I insert CD into CD drive, it doesn't start to rotate. So I can't make fresh Install of OS 3.9 SE under Amiga, I have to do this under FS-UAE. Which 060.library will be the best for this card?
Re: TF360 - Shapeshifter won't start
Posted: 06 Mar 2023 22:59
by terriblefire
OSH wrote: 06 Mar 2023 21:57
Shapeshifter should work. You'll need to use the MuMove4K instead of the shapeshifter bundled tool. This is well documented.
The CD Drive support is not yet perfect but you're on your own for software support here. I'd assume the TF360 CD support is the issue. Its something i'm working on.
Posted: 06 Mar 2023 23:05
by OSH
Steve, I'm Using MuMove4K with prepareemul parameter. But it doesn't help... Fusion works and loads MacOS, Shapeshifter doesn't...
Posted: 06 Mar 2023 23:08
by terriblefire
OSH wrote: 06 Mar 2023 23:05
I can take a look when i get a minute. cant think why it would work on the 1200 and not the CD32.
Posted: 07 Mar 2023 05:21
by arti040
1. try first with default driver and turn MMU OFF in Shape Shifter Video configuration
2. CD-ROM - if it works in FUSION (the same MacOS, I assume), it should work with Shape Shifter as well. Are you sure you got a proper device and unit set up?
Posted: 07 Mar 2023 10:05
by dalek
I don't think Shapeshifter has proper 060 support. I know Fusion does - so just use that and be happy?
Posted: 07 Mar 2023 10:11
by alexh
dalek wrote: 07 Mar 2023 10:05
If you're using MacOS < 8.1 it works, you have to jump through some hoops to get it to work but it does work.
Posted: 08 Mar 2023 21:37
by OSH
arti040 wrote: 07 Mar 2023 05:21
1. Didn't help, BUT: two times I saw welcome MacOS screen. First time it's frozen, second time system was loaded completely, but then iI had instant reset.
2. I said about CD-ROM under AmigaOS not MacOS
No, because is significant slower and can't use MuEVD driver.
alexh wrote: 07 Mar 2023 10:11
But which hoops? REMAP8K is disabled, A/ROSE too.
Posted: 08 Mar 2023 21:40
by terriblefire
OSH wrote: 08 Mar 2023 21:37
Like i said CD support is WIP right now. it does work but maybe not perfectly all the time.
Posted: 09 Mar 2023 00:09
by OSH
Steve I understand, but for me more important is, why I can't launch ShapeShifter correctly. I need a confirmation or negation from someone, who own TF360.
