Page 1 of 1
7406 and Floppy Fix
Posted: 22 Jun 2022 16:56
by PeckPeekPoke
From what I've attempted to glean from photos, here is a sketch.
Could someone verify this?
Besides the 10kSil added to the WD1772, when adding resistors to fix floppy performance; on the 7406, there should be five 100k resistors wired from the pins coloured red in the drawing, (2,4,6,8,10) all terminating together at pin14.
Is this the correct ? :?
Re: 7406 and Floppy Fix
Posted: 22 Jun 2022 17:03
This topic has all the info.
https://exxosforum.co.uk/forum/viewtopi ... =17&t=1395
PeckPeekPoke wrote: 22 Jun 2022 16:56 Besides the 10kSil added to the WD1772, when adding resistors to fix floppy performance; on the 7406, there should be five 100k resistors wired from the pins coloured red in the drawing, (2,4,6,8,10) all terminating together at pin14.
Yep sounds correct. But 1k not 100k.
Posted: 22 Jun 2022 21:05
by PeckPeekPoke
Thank you! 8-)
