Are these scope readings healthy? TT issues
Posted: 01 Mar 2022 21:29
Hi all,
I am trying to get my TT sorted. It has an underlaying problem which means I need to drop all the data and address bus SIPS to 2.2k to get any kind of stability. While I was generally happy, I lately found I was getting bus errors on SCSI access. After lengthy testing I decided to socket my address and data SIL resistors to investigate. I found that default 10k is unusable, crashes on hard disk detection (HD driver) 4.7k sometimes passes but then crashes later. 2.2k passes and the system works, but then has some low level bus errors cropping up here and there - so I want to find the cause.
I put 10k SILS back in and started scoping. I found that removing the STRAM board (the TT still has 2mb on the motherboard so can still operate) drive detection passes with 10k SILS installed. But loading the FreeMint OS (my daily driver OS) freezes on boot during 'setting up fstab' (which is where the drives are detected and mounted in the OS) This is an interesting development.
EDIT: Also noting that removing the TT RAM board (but leaving ST-RAM board installed) works too. So this does not seem to be an issue with either RAM board. Bus loading? As I heard Exxos speak about before. And I know we generally fix this by lowering SIL values, but I just want to understand why as people in the TT domain are always telling me 2.2k might damage components in the system, so if possible I want to find the root cause.
Here are some scopes, blue is 5v direct from the PSU and yellow is connected to 5v on the STRAM board.
I am not so great at reading the results, I took photos at various different zooms/scales and at 20mv for both channels.
Ps - I have two PSUs and tested them both, behaviour is the same. The main PSU is recapped and tests 5.1v and 11.9v, negative rails pass fine too.
