Page 1 of 1
Ste reset button button
Posted: 26 Jan 2022 12:19
by richud
My STe came with no reset button button - I couldn't find a 3D one to print so knocked this up in openscad - should tightly snap fit *IF* printing with highest quality/smallest/finest layers you can and your extrusion amount (Material > Flow) is just right (calculated mine to 95.0 in Cura for my Ender Pro 3) as the margins are very fine.
Reset button on mine is 2.8mm square - so if yours isn't this won't help!
If your machine isn't calibrated or if it's too tight I would suggest knocking it back the Flow 1 at a time and reprinting (obv. it's tiny and only takes a few mins to print so not a major hassle) as this will fractionally increase the internal diameter of the snap bits
- [also it sticks out about 1 mm longer than the original]
atati_st_reset_button3.stl
(152.23 KiB) Downloaded 201 times
!Message from: Moderator
@richud, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Re: Ste reset button button
Posted: 26 Jan 2022 13:17
:bravo: :thanksyellow:
