Page 1 of 2
Shapeshifter not work with IDE TF1260
Posted: 01 Dec 2021 01:24
by hardgb
I have a problem but first I apologize if I'm posting in the wrong place...
I'm using TF1260's IDE port and it has a great transfer rate but I noticed that after using this IDE I couldn't use Shapeshifter anymore. The screen freezes right after the shapeshifter tries to load MacOS. But when I use the A1200 IDE again the emulator works again.
Does anyone know how I can solve this problem? :(
Re: Shapeshifter not work with IDE TF1260
Posted: 01 Dec 2021 07:58
by Higgy
@hardgb are you overclocking? Does it still freeze at 50Mhz?
There is a known issue with the TF1260 IDE when overclocking.
Posted: 01 Dec 2021 09:06
by arkadiusz.makarenko
hardgb wrote: 01 Dec 2021 01:24 I have a problem but first I apologize if I'm posting in the wrong place...
Emulator may not be compatible with ehide.device driver?
Posted: 01 Dec 2021 13:30
by hardgb
arkadiusz.makarenko wrote: 01 Dec 2021 09:06
I'm suspecting the shapeshifter is not compatible with the ehide.device drive?
Because even with the overclock the shapeshifter worked on the A1200's IDE, it was just using the Shapeshifter's IDE that it didn't work.
Posted: 01 Dec 2021 13:32
by terriblefire
hardgb wrote: 01 Dec 2021 13:30 I'm suspecting the shapeshifter is not compatible with the ehide.device drive?
I mean at a hardware level the interfaces are pretty much identical. maybe @erique would have some thoughts?
Posted: 01 Dec 2021 13:42
by hardgb
terriblefire wrote: 01 Dec 2021 13:32
So it must be some configuration of the Shapeshifter itself... :roll:
I will analyze a little more
Posted: 01 Dec 2021 13:59
by hardgb
Wow!!!
Got it, here it worked.
I just went into the settings and changed SCSI.DEVICE to EHIDE.DEVICE and it worked.
Perfect! Thank you all for your help.
photo1638366649 (1).jpeg (142.93 KiB) Viewed 4441 times
Posted: 01 Dec 2021 14:14
by supaduper
Excellent well done fella. ehide.device for the win ! ;)
Posted: 01 Dec 2021 16:20
by terriblefire
hardgb wrote: 01 Dec 2021 13:59 Wow!!!
Nice. Where did you get the MacOS image?
Posted: 01 Dec 2021 17:25
by hardgb
terriblefire wrote: 01 Dec 2021 16:20
It's been a long time, I must have the links saved in my email. Can I paste the links right here?
