Midlevel electronic engineering with Kicad (French teacher) - usb traces - power planes
Posted: 10 May 2021 16:14
This is in French, but I found it quite instructive. The speaker is a teacher at a French University.
This lesson deals with
- how to setup differential traces with appropriate impedance, applied to routing from a USB connector to the target micro-controller. In passing, the minimal requirement of having a 4 layer pcb to be able to support the full speed of USB is explained a little bit.
- how to use power planes (abstract : organize the different areas powered with different voltage levels, use several vias to limit the impedance)
- how to route the oscillation circuit of a microcontroller to minimize electronic noise. (abstract : a dedicated ground plane area, enclosed with vias)
