Page 1 of 1
DSP508 half voltage output fix
Posted: 16 Mar 2021 18:12
I've had a couple of the DSP508 which are only outputting half voltage (under load) ..
It was found in both cases a bad joint on the heatsink, which is being used as part of the mains circuit it seems :roll:
Re-soldered..
Done! The voltage is showing higher than it should as they battery is going in my meter, but it's actually 5.02V!
Re: DSP508 half voltage output fix
Posted: 16 Mar 2021 19:46
The very similar ASP34 suffers from bad joints on the heatsink as well...
Posted: 17 Mar 2021 01:13
by kodak80
Thank you @exxos I had a PSU here that was outputting half-voltages under load. This made me check the heatsink pin soldering and I found a crack so re-soldered all heatsink pins and viola the PSU is working again and outputs normal voltages again. :cheer:
