Page 1 of 1
few troubleshooting questions
Posted: 19 Sep 2020 11:34
by oggie
- What's the jumper for by the ide header? I can't read the silscreen on mine.
- What type of image shold I write to the cf card? I mean, what version of the OS? I had a card from my 1200 that I tried, and it just gave me blank screen. It's WB 3.1
- Without a CF card, it does show the cd32 disc logo. Is that an indication that the card should work?
- Can I hurt anything if I attach a cf card reader backwards. The one I have doesn't have pin1 indicated, so I'm unsure of the orientation.
Re: few troubleshooting questions
Posted: 19 Sep 2020 11:46
by supaduper
you need a jumper on two pins next to IDE as these are the Card enable/ Disable pins
see pic below
it will then boot with your A1200 cf card
- TF330 disable jumper.jpg (167.14 KiB) Viewed 6677 times
Posted: 19 Sep 2020 15:31
by oggie
- IMG_20200919_112336.jpg (176.17 KiB) Viewed 6652 times
Well loook at that! That's all I needed was the jumper. Thanks!
Guess I need to build a proper image for the cd32 since it's looking for a floppy.
Posted: 19 Sep 2020 15:36
by supaduper
Just comment the DF0: out in the Startup-Sequence no need to make another CF
Posted: 19 Sep 2020 17:10
by oggie
Thanks.
But what I mean was I need to copy this cf card and get it working on a new one.
Posted: 19 Sep 2020 17:31
by supaduper
I use Winimage
couple of clicks and your done :) link
https://www.winimage.com/download.htm
Posted: 19 Sep 2020 18:01
by alenppc
I recommend Win32diskimager, it’s open source.
Posted: 21 Sep 2020 14:02
by oggie
supaduper wrote: 19 Sep 2020 15:36
That worked. It now boots and I can use it just like my a1200.
Now I need to get it to boot directly into x-bench and be controllable with a joystick.
