Page 1 of 1
[Atari TT] Width column row isn't constant
Posted: 25 May 2020 16:13
by sappas
Hello,
I suspect c300868 TT video chip, my mother board is a rev A or B,
As you can see the width of column row.
Any advice ?
Thanks
Sappas
Atari TT column row width issue
Re: [Atari TT] Width column row isn't constant
Posted: 25 May 2020 16:39
by stephen_usher
Looks more like the monitor isn't able to sync with the TT's output and so you're getting moire patterns on the screen.
Posted: 25 May 2020 21:25
by sappas
I've to take a better photography, and with compression artefact but on my falcon, it's perfect !
Posted: 25 May 2020 22:58
by stephen_usher
The Falcon outputs standard VGA timed signals, the TT doesn’t. They are outside the acceptable range for standard VGa.
Posted: 08 Jul 2020 08:32
by sappas
stephen_usher wrote: 25 May 2020 22:58 The Falcon outputs standard VGA timed signals, the TT doesn’t. They are outside the acceptable range for standard VGa.
Hello, You're rigth, finally between my twenty 5/4 monitor i've found a LG L1915S witch is less bad.
Thanks a lot, for indicate me the right parh.
This issue is close
Posted: 08 Jul 2020 09:19
My MSTE shows similar problems when used with a VGA display and in Med-Res. It's quite possible to tweak the settings in the monitors control panel to improve the picture sufficiently to make it acceptable.
I was able to fine tune the horizontal size and use auto contrast to get a great picture. Happens a lot on ST's at Med-Res using VGA displays.
