Page 1 of 1
TF534 Open Board View
Posted: 28 Mar 2019 14:53
by terriblefire
There is an open board view file available for the TF534 builders to help diagnose.
https://github.com/terriblefire/tf534
Screenshot 2019-03-28 at 14.49.58.png (113.85 KiB) Viewed 7377 times
Re: TF534 Open Board View
Posted: 28 Mar 2019 15:53
by go0se
Fantastic! I was just thinking the other day how an amigapcb.org type solution for the 534 would make my life a lot easier and along comes pretty much exactly what I wanted!
Cheers for putting this together TF, Is there much work involved in (I assume?) deriving this layout from the Eagle files?
Posted: 28 Mar 2019 16:26
by terriblefire
The first time i did it it was work. Then i created a bat file i can drag things on and its done automatically.
Posted: 28 Mar 2019 19:17
by go0se
Excellent, this really will be a massive help. Can said batch file be used to produce versions for the 530 and 330 or am I just being greedy now? :)
Posted: 28 Mar 2019 20:04
by go0se
This really is gold! Decided to attack my non booting 534, logically starting with the connections to/from X1 and within 5 mins I've located an invisible short between pins 2 and 3 of trigger buffer IC4 that didn't show up with the scope. A quick re-flow later and it's booting to Diagrom serial only with a nice pink screen on the video output - :) Onward!
Again TF, a really big thank you for releasing this! Brilliant.
Posted: 28 Mar 2019 21:26
by terriblefire
go0se wrote: 28 Mar 2019 19:17 Excellent, this really will be a massive help. Can said batch file be used to produce versions for the 530 and 330 or am I just being greedy now? :)
Not really much point since you can "show <netname>" with TF530.
I have already pushed the TF330 OBV to github.
Posted: 29 Mar 2019 09:22
by apacz
Please forgive me lame question:
opening in eagle9.3 :
Loading /home/michal/tf534-master/tf534_obv.brd ...
Error:
line 1, column 1: Expecting tag opening
Opening in OpenBoardView i can see only capacitors. What do you use for viewing?
apacz
Posted: 29 Mar 2019 09:38
by terriblefire
Its an open board view file. not eagle.
FLip the board by pressing space.
Posted: 29 Mar 2019 09:46
by apacz
10x works like a charm
