Page 1 of 3
TF330 WiFi?
Posted: 23 Mar 2019 20:14
by trixster
Hi,
Great project, I love my TF330, it’s working great so many thanks to all you guys and especially to Alen who ‘built’ my card :)
Is the WiFi currently working or is it waiting to be enabled in future firmware?
Is it’s the former, what sets need to be taken to start using it? If the latter, is it likely to get made available soon enough?
Re: TF330 WiFi?
Posted: 23 Mar 2019 20:41
by terriblefire
It works slowly.
Just needs a pppd setup and roadshow etc can dial into the pppd on a Rpi
Re: TF330 WiFi?
Posted: 24 Mar 2019 09:53
by trixster
Nice. Does anyone have a link to a suitable tutorial to get this set up?
Re: TF330 WiFi?
Posted: 24 Mar 2019 10:05
by terriblefire
I'll try and do one when i'm back from hospital later. Its not hard. You just need a rpi with pppd setup (or any linux box TBH).
You will also need to flash in the zmodem firmware to an ESP8266 module... if you want to get a headstart with that.
ESP firmware is found at https://github.com/terriblefire/terribl ... er/esp8266
At some point i'll try and put the pppd software in the ESP module itself. It should be possible
Re: TF330 WiFi?
Posted: 27 Apr 2019 14:18
by 8 Bit Dreams
Any news here? Wanna try to set it up..
Total noob manual is needed :lol:
So i need an ESP8266 ESP-01S Serial Wireless WIFI Module, right?
Re: TF330 WiFi?
Posted: 27 Apr 2019 15:33
by terriblefire
Yes.. and then ppp setup on a rpi or a linux box on your LAN.
I had a card setup with it.
There are too many thing on the go a the moment for me to look at this.
Re: TF330 WiFi?
Posted: 09 Jul 2019 13:52
by E-Penguin
Is the ESP8266 connected via serial? Maybe installing a SLIP firmware directly on it would be the simplest solution, then no need to install a pppd somewhere.
https://github.com/krzychb/esp-just-slip
Re: TF330 WiFi?
Posted: 09 Jul 2019 15:45
by terriblefire
E-Penguin wrote: 09 Jul 2019 13:52 Is the ESP8266 connected via serial? Maybe installing a SLIP firmware directly on it would be the simplest solution, then no need to install a pppd somewhere.
Yup. Its just wired directly to the serial.device. There may be lots of ways to get working wifi.
Re: TF330 WiFi?
Posted: 14 Aug 2019 22:19
by sugar
Did you have a chance to try it yet?
I'll give it a go in a couple of weeks time.
Re: TF330 WiFi?
Posted: 16 Aug 2019 16:35
by terriblefire
I’m gonna have a play with this on the TF360 this weekend...
