Page 1 of 1
MuteDucks Build Log
Posted: 23 Feb 2019 11:53
by muteDuck
Starting a tf530 board build so at moment got the PCB and looking to order parts. Got one quick question which is for the cpld have I found the right one on digikey:
https://www.digikey.co.uk/product-detai ... -ND/826991
Now the other suggested products may suggest I have as some of the other components such as the sram is showing up there.
Re: MuteDucks Build Log
Posted: 01 Mar 2019 15:55
by muteDuck
So finally got a diagrom and plopped it in to the 500+. So turns out there looks to be potential memory issue although seeing some evidance of battery damage on the board:
https://photos.app.goo.gl/r2J7fsx2qn2bssoWA
@U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to paula. Now starting normal startuptext etc
[0mAmiga DiagROM V1.1 - 27-Oct-18 - By John (Chucky/The Gang) Hertell
Testing if serial loopbackadapter is installed: <> NOT DETECTED
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
Checking status of mousebuttons for different startups:
Set all Interrupt enablebits (INTENA $dff09a) to Disabled: Done
Set all Interrupt requestbits (INTREQ $dff09c) to Disabled: Done
Set all DMA enablebits (DMACON $dff096) to Disabled: Done
Testing if OVL is working: OK
- Parallel Code $fe - Test UDS/LDS line
- Test of writing word $FFFF to $400 OK
- Test of writing word $00FF to $400 OK
- Test of writing word $FF00 to $400 OK
- Test of writing word $0000 to $400 OK
- Test of writing byte (even) $ff to $400 OK
- Test of writing byte (odd) $ff to $401 OK
- Parallel Code $fd - Start of chipmemdetection
Addr $00000400 Write: $AAAAAAAA Read: $AAAAFFAA FAILED
Addr $00000400 Write: $55555555 Read: $5555FF55 FAILED
Addr $00000400 Write: $F0F0F0F0 Read: $F1F0FFF0 FAILED
Addr $00000400 Write: $0F0F0F0F Read: $0F0FFF0F FAILED
Addr $00000400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00008400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00008400 Write: $55555555 Read: $5555FF55 FAILED
Addr $00008400 Write: $F0F0F0F0 Read: $F1F0FFF0 FAILED
Addr $00008400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00008400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00010400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00010400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00010400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00010400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00010400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00018400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00018400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00018400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00018400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00018400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00020400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00020400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00020400 Write: $F0F0F0F0 Read: $F3F0FFF0 FAILED
Addr $00020400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00020400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00028400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00028400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00028400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00028400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00028400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00030400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00030400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00030400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00030400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00030400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00038400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00038400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00038400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00038400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00038400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00040400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00040400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00040400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00040400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00040400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00048400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00048400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00048400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00048400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00048400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00050400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00050400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00050400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00050400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00050400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00058400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00058400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00058400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00058400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00058400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00060400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00060400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00060400 Write: $F0F0F0F0 Read: $F3F0FFF0 FAILED
Addr $00060400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00060400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00068400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00068400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00068400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00068400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00068400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00070400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00070400 Write: $55555555 Read: $5555FF55 FAILED
Addr $00070400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00070400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00070400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00078400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00078400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00078400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00078400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00078400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00080400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00080400 Write: $55555555 Read: $5555FF55 FAILED
Addr $00080400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00080400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00080400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00088400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00088400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00088400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00088400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00088400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00090400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00090400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00090400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00090400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00090400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00098400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00098400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00098400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00098400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00098400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000A0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000A0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000A0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000A0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000A0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000A8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000A8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000A8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000A8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000A8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000B0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000B0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000B0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000B0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000B0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000B8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000B8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000B8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000B8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000B8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000C0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000C0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000C0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000C0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000C0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000C8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000C8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000C8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000C8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000C8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000D0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000D0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000D0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000D0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000D0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000D8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000D8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000D8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000D8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000D8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000E0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000E0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000E0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000E0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000E0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000E8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000E8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000E8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000E8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000E8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000F0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000F0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000F0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000F0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000F0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $000F8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $000F8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $000F8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $000F8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $000F8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00100400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00100400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00100400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00100400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00100400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00108400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00108400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00108400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00108400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00108400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00110400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00110400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00110400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00110400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00110400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00118400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00118400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00118400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00118400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00118400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00120400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00120400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00120400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00120400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00120400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00128400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00128400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00128400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00128400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00128400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00130400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00130400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00130400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00130400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00130400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00138400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00138400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00138400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00138400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00138400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00140400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00140400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00140400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00140400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00140400 Write: $00000000 Read: $FE00FF00 FAILED
Addr $00148400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00148400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00148400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00148400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00148400 Write: $00000000 Read: $FC00FF00 FAILED
Addr $00150400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00150400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00150400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00150400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00150400 Write: $00000000 Read: $FC00FF00 FAILED
Addr $00158400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00158400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00158400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00158400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00158400 Write: $00000000 Read: $4000FF00 FAILED
Addr $00160400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00160400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00160400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00160400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00160400 Write: $00000000 Read: $FC00FF00 FAILED
Addr $00168400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00168400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00168400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00168400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00168400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00170400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00170400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00170400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00170400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00170400 Write: $00000000 Read: $FC00FF00 FAILED
Addr $00178400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00178400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00178400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00178400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00178400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00180400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00180400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00180400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00180400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00180400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00188400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00188400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00188400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00188400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00188400 Write: $00000000 Read: $C000FF00 FAILED
Addr $00190400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00190400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00190400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00190400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00190400 Write: $00000000 Read: $0000FF00 FAILED
Addr $00198400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $00198400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $00198400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $00198400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $00198400 Write: $00000000 Read: $0000FF00 FAILED
Addr $001A0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001A0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001A0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001A0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001A0400 Write: $00000000 Read: $C000FF00 FAILED
Addr $001A8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001A8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001A8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001A8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001A8400 Write: $00000000 Read: $4000FF00 FAILED
Addr $001B0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001B0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001B0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001B0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001B0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $001B8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001B8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001B8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001B8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001B8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $001C0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001C0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001C0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001C0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001C0400 Write: $00000000 Read: $4000FF00 FAILED
Addr $001C8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001C8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001C8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001C8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001C8400 Write: $00000000 Read: $4000FF00 FAILED
Addr $001D0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001D0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001D0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001D0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001D0400 Write: $00000000 Read: $4000FF00 FAILED
Addr $001D8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001D8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001D8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001D8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001D8400 Write: $00000000 Read: $C000FF00 FAILED
Addr $001E0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001E0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001E0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001E0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001E0400 Write: $00000000 Read: $E000FF00 FAILED
Addr $001E8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001E8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001E8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001E8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001E8400 Write: $00000000 Read: $0000FF00 FAILED
Addr $001F0400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001F0400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001F0400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001F0400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001F0400 Write: $00000000 Read: $0000FF00 FAILED
Addr $001F8400 Write: $AAAAAAAA Read: $FFAAFFAA FAILED
Addr $001F8400 Write: $55555555 Read: $FF55FF55 FAILED
Addr $001F8400 Write: $F0F0F0F0 Read: $FFF0FFF0 FAILED
Addr $001F8400 Write: $0F0F0F0F Read: $FE0FFF0F FAILED
Addr $001F8400 Write: $00000000 Read: $0000FF00 FAILED
NO Chipmem detected
- Parallel Code $fc - Start of non autoconfig fastmemdetection (as no chip found/startup check)
- No fastmem found, Autoconfig ram NOT checked
- Parallel Code $fb - Memorydetection done
- Parallel Code $80 - NO Chipmem detected
- NO MEMORY FOUND - HALTING SYSTEM
Posted: 06 Mar 2019 20:43
by kludge
muteDuck wrote: 23 Feb 2019 11:53
I'm no expert, but that looks like the right part, indeed.
