Page 1 of 28
The TF330 is here
Posted: 19 Nov 2018 18:03
by terriblefire
First look at the new board
Re: The TF330 is here
Posted: 19 Nov 2018 18:35
by supaduper
They look great Steve and a +1 for the packaging by JLC :)
Posted: 19 Nov 2018 18:41
by terriblefire
A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
Posted: 19 Nov 2018 18:42
by terriblefire
supaduper wrote: 19 Nov 2018 18:35 They look great Steve and a +1 for the packaging by JLC :)
Perfect box for sending 328s to you in :)
Posted: 19 Nov 2018 18:50
terriblefire wrote: 19 Nov 2018 18:41 A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
wow! The last boards I got were from JLC.. will see if I can check quality on one later..
Posted: 19 Nov 2018 19:04
Mine isn't perfect, but not as bad as yours I think..
Posted: 19 Nov 2018 19:06
by terriblefire
exxos wrote: 19 Nov 2018 18:50
Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.
Posted: 19 Nov 2018 19:07
terriblefire wrote: 19 Nov 2018 19:06 Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.
The 0.8mm holes look ok on my board, looks like the smaller drill holes are running out..
Might be worth reporting a quality problem to them ?
Posted: 19 Nov 2018 19:59
by alenppc
That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
Posted: 19 Nov 2018 20:15
by terriblefire
alenppc wrote: 19 Nov 2018 19:59 That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
Its 1.6mm. All my TF328s have been that. They fit no issue.
EDIT: Although i will say they were supposed to do bevelled edges and they didnt.
