And part 2 of the upgrade after a coffee and little cake :) First off I realise that the Acid Stereo had a socket fitted to it, so I pulled that off to reduce overall height,
- IMG20260315163457.jpg (287.96 KiB) Viewed 794 times
And yes, that pin is supposed to be missing, it mentions it in the install guide.
In the end I opted to pick A4 off the CPU, it's the blue wire coming from the CPU board here, the other 2 wires being for the Incognito Gold upgrade.
- IMG20260315164613.jpg (425.27 KiB) Viewed 794 times
Final install looks something like this:
- IMG20260315170340.jpg (311.44 KiB) Viewed 794 times
I then fed the stereo cable across the board to the front right corner of the Faraday cage:
- IMG20260315170357.jpg (464.66 KiB) Viewed 794 times
The reason being is that the Faraday cage has a slight gap here where the cable can be pinched when the screws are tightened:
- IMG20260315170859.jpg (281.5 KiB) Viewed 794 times
I pushed the cable back in a little for strain relief before tightening the screw. After that I was able to fit the rest of the Faraday cage screws.
I then fed the cable round under the PSU and into the strain relief that was originally intended for the RF cable:
- IMG20260315171353.jpg (213.85 KiB) Viewed 794 times
I then buttoned it all up:
- IMG20260315171639.jpg (268.85 KiB) Viewed 794 times
And then a quick test with Yoomp!
- IMG20260315173833.jpg (211.15 KiB) Viewed 794 times
Of this is a good test as it tests both stereo and th Incognito Gold at the same time so I know I didn't break anything during the upgrade :)
It's a nice simple stereo upgrade thats for sure and does offer other things too. I can recommend as in something like an XL or XE it'll be very simple to do.
