Page 7 of 8
Re: ATW800/2 in a MonSTErbo powered STE
Posted: 22 Aug 2026 12:33
by JezC
HigashiJun wrote: 22 Aug 2026 11:46
JezC wrote: 22 Aug 2026 11:24
Thanks...and what's at the other end inside the STE? I'm intrigued with what's providing the Ethernet functionality 8-)
Oh, you meant the source...l
It's an ENC28J60 module connected to the MonSTErbo.
Thanks - so using SPI off the MonSTErbo, nice
It'll be interesting to see how well it performs!
Posted: 22 Aug 2026 13:14
by HigashiJun
JezC wrote: 22 Aug 2026 12:33
I don't expect terrific speeds...
Here's what Alan wrote:
For the ENC28J60 and UIP, I've submitted the code to sqward for inclusion in UIP tool and the source code is available. Also the ENC28J60 is actually a pretty slow chip, and I've had about 150Kbytes/s using curl to test throughput. NOTE: The ENC28J60 can't run at the fastest SPI speeds of the MonSTerbo.
Posted: 22 Aug 2026 14:36
by JezC
Good to know.
Thanks @HigashiJun - probably still quicker than floppy or serial file transfer.
I'm still debating what IDE storage to use with this STE.. after I sort out the graphics issues.
Posted: 15 Nov 2026 09:45
by HigashiJun
I was fiddling with my setup today and upgraded the ATW800/2 to its last Seurat Firmware (160 MHz) and to its last XVDI drivers.
I have also installed Freemint along Jinnee desktop and the result is quite nice:
- 1.JPG (622.64 KiB) Viewed 56 times
I have no artefacts on the menu bar like I had on plain TOS and everything seems to run smoothly so far.
The Monsterbo still runs perfectly at 40Mhz on the 68EC020 CPU.
:D
Posted: 15 Nov 2026 10:01
HigashiJun wrote: 15 Nov 2026 09:45
:D
Might have to try this on my MSTE+ATW800/2. That desktop reminded me of RiscOS when I first saw the picture
Posted: 15 Nov 2026 10:02
by HigashiJun
rubber_jonnie wrote: 15 Nov 2026 10:01
Go for it !
Posted: 15 Nov 2026 10:22
HigashiJun wrote: 15 Nov 2026 10:02
Go for it !
The only thing is that I don't have a Monsterbo, just my MSTE at 16Mhz, and I know Freemint doesn't play well with just 4MB.
I can certainly try other desktops at higher resolutions though.
Posted: 15 Nov 2026 10:36
by HigashiJun
rubber_jonnie wrote: 15 Nov 2026 10:22
Not even a Monster ?
You would have enough RAM for Freemint.
Posted: 15 Nov 2026 10:40
HigashiJun wrote: 15 Nov 2026 10:36
No, not even a Monster.
4MB is enough to run Freemint, and I have in fact done so, however it's not really enough to do anything useful and I continually ran out if I tried to do anything useful with it.
Posted: 15 Nov 2026 16:34
by Darklord
I tried the bare FreeMINT setup on my ATW800/2 Mega STe, same
base install I have on my STacy and I had no end of problems with
memory, so gave up.
Waiting on Alan H. to finish the Mega STe version of the MonSTerbo.
I think that will be a glorious day. :)
