Page 30 of 57
Re: A5000 - diving in at the deep end!
Posted: 20 Oct 2023 14:07
stephen_usher wrote: 20 Oct 2023 13:58
What's your routing table like? If no route then no ping.
It shouldn't really need a routing table to ping something on the same subnet, like another PC or the gateway, which is in the settings, but I can't even ping anything local. That's not 100% true, I can ping the localhost address and the local IP address.
Well, unless the A5000 TCP/IP stack is weird and I'm missing something. Or it doesn't like my 10/100 switch.
Posted: 20 Oct 2023 14:31
by HigashiJun
Ok, slow but good progress !
Posted: 20 Oct 2023 15:19
by stephen_usher
rubber_jonnie wrote: 20 Oct 2023 14:07
Even the local physical interface needs a route to the subnet it's connected to, e.g.
% netstat -r
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
default router 0.0.0.0 UG 0 0 0 eth0
163.1.22.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
link-local 0.0.0.0 255.255.0.0 U 0 0 0 eth0
In this case the "local" network is 163.1.22.0. There's also a default route out to the router.
Posted: 20 Oct 2023 16:19
stephen_usher wrote: 20 Oct 2023 15:19
% netstat -r
I'll check it out, I'm used to every OS I've ever used building a routing table so that may be catching me out
Posted: 20 Oct 2023 16:22
by stephen_usher
Yeah, usually the route is added automatically.
Posted: 02 Nov 2023 15:23
Ok, so managed to get this:
- Screenshot 2023-11-02 at 15.19.01.png (839.98 KiB) Viewed 1328 times
Supposedly fully working for £16, so with the cabling coming from Cricklewood electronics for about the same, I should be able to set up a test BNC network and hopefully, plus since it has AUI, I can hopefully test all the elements of the A5000 NIC to see if they are all working.
Fun and games this A5000 when it comes to networking.
Posted: 02 Nov 2023 16:17
by stephen_usher
:dualthumbup:
Posted: 03 Nov 2023 00:53
by HigashiJun
Fingers crossed !
:crossed1:
Posted: 03 Nov 2023 09:57
Also heard back from CJE, who have been very helpful, and I'm going to try a blank system with uniboot and drivers supplied by them, see if I get any further.
Will be dead easy to set up now I have BlueSCSI installed, I can just drop in a spare SD card and blank image, so it'll make things clean and easy.
Fingers crossed I'll have this sorted soon.
Posted: 03 Nov 2023 10:27
So I tried running the e1info command as suggested by CJE and I can see when executing multiple times that the RX & TX frame counters are incrementing, as is the unwanted frames counter.
- PXL_20231102_141409504-edit-20231102142130.jpg (398.97 KiB) Viewed 1243 times
So I'm positive something is working and it's just a matter of time :)
