Page 23 of 43
Re: PiStorm Chat
Posted: 09 Oct 2023 18:59
by Darklord
dad664npc wrote: 08 Oct 2023 03:55 Showing Pi3 for now as it offers the lowest profile. You can hopefully see that there is no way this assembly fits under the keyboard. So the only way the PiStorm will fit inside an STfm is if the PiStorm is extended off the CPU socket.Something like this -
Okay, obviously the option with the extender is out (especially since it seems it doesn't work, going by the other posts).
The PiSTorm does plug into the 68000 CPU socket though, right. Same thing the Pak 68/3 board plugs into. On the STacy,
that's in the middle of the motherboard, left side'ish, not under the keyboard. Well, partially under the keyboard but
mostly not.
However, it still comes down to height. I think the Pak 68/3 board is considerably longer and wider than the PiStorm but
it's not very tall. The PiSTorm board/Pi3-4 combo would probably make it too tall to allow everything to be closed up. It
is really close with a Pak 68/3 board. Well, it was just a thought. :)
Thanks...
PS Here's some pictures of a Pak 68/3 board close up:
Pak Board01.jpg (180.36 KiB) Viewed 2982 times
Pak Board02.jpg (68.3 KiB) Viewed 2982 times
Pak Board03.jpg (98.43 KiB) Viewed 2982 times
Re: PiStorm Chat
Posted: 09 Oct 2023 19:02
by Darklord
dad664npc wrote: 08 Oct 2023 07:17 I'm not a game player, but over the last few months of development, I have occasionally tested the 1M folder contents. Pretty much all run. Note, sometimes you will have to change TOS ROM to load/play
If there is any particular game you would like to me check, let me know
No, no particular game, I was just wanting to see where things stood.
This is encouraging news though, for those people who want to dive
into the PiSTorm and use it. If they do gaming a lot they won't have
to pass on this option.
Thanks! :)
Re: PiStorm Chat
Posted: 30 Oct 2023 01:49
by Darklord
Steve wrote: 08 Jul 2022 18:03 @Badwolf I ordered a Pistorm today (& a cool ribbon-cable 68k relocator) today, so I'll be able to help with testing soon.
Can you please post a link and items list for the ST only version? Thanks...
Re: PiStorm Chat
Posted: 30 Oct 2023 05:50
by Steve
There's no such thing as an ST only version, it's just a regular Amiga Pistorm. The type you'd put in an a500.
Re: PiStorm Chat
Posted: 30 Oct 2023 18:32
by Darklord
Steve wrote: 30 Oct 2023 05:50 There's no such thing as an ST only version, it's just a regular Amiga Pistorm. The type you'd put in an a500.
Ah, so if I've got this straight, you go to an Amiga source, buy the A500 Pistorm and then use that with one
of the compatible Pi models and that would (theoretically) work with an ST (not STe).
Thanks.
Re: PiStorm Chat
Posted: 30 Oct 2023 19:23
by LarryL
Darklord wrote: 30 Oct 2023 18:32
Thanks.
Exactly
But for an STE you need: 1) CPU in PLCC68 socket, and 2) PLCC to DIP adapter
Re: PiStorm Chat
Posted: 31 Oct 2023 03:44
by Darklord
LarryL wrote: 30 Oct 2023 19:23 But for an STE you need: 1) CPU in PLCC68 socket, and 2) PLCC to DIP adapter
Thanks! :)
Re: PiStorm Chat
Posted: 31 Oct 2023 03:55
by Darklord
Would this Pi version be acceptable?
https://tinyurl.com/hd4zkyv2
Thanks...
Re: PiStorm Chat
Posted: 31 Oct 2023 07:36
by dad664npc
The Atari-PiStorm project has been developed to use Pi4's. However, it has been found that reasonable performance is available using a Pi3A+. Pi Zero 2W, and Pi3B's also work, but they are slow.
The biggest problem facing us at the moment is how the hell to install the hardware. ST's are the biggest problem in this area. STE's have a PCB designed and a few Users are having some manufactured.
Re: PiStorm Chat
Posted: 31 Oct 2023 16:02
by Darklord
dad664npc wrote: 31 Oct 2023 07:36 The Atari-PiStorm project has been developed to use Pi4's. However, it has been found that reasonable performance is available using a Pi3A+. Pi Zero 2W, and Pi3B's also work, but they are slow.
Hmm, I see. I was thinking about the Pi3A+ because of the low form factor (profile) and trying
to fit it into a STacy.
The PiSTorm board does just plug into the (socketed) 64-pin CPU, right? Aside from a Pi version,
nothing else is needed for an ST?
Someone mentioned removing things from a Pi4, like the connectors but I dunno...
Guess I'll have to rethink a STacy version.
Thanks for the info. :)
