Page 3 of 3
Re: STE: Thanks for the memory?
Posted: 23 Dec 2025 21:09
by Steve
@LeakyBatz there isn't an STe specific PSU upgrade kit. They're PSU specific. So you would need to check what PSU you have, and order the corresponding kit.
Posted: 27 Dec 2025 18:06
by LeakyBatz
Cheers, have placed an order!
Posted: 27 Dec 2025 23:16
LeakyBatz wrote: 23 Dec 2025 20:12 Thanks @exxos I'll have a look at them.
Regarding the memory, errr.....I guess I need to pull out my 386 & check them. They are from a bag of previously tested sticks, though.
Would this be the kit for recapping the Atari STE PSU?
Your 386 may well have parity RAM installed so be sure to check. If it has 8 RAM IC's it should be OK, however if it only has 3 IC's you'll need to check the chips against their data sheets as I have run into 3 chip SIMMs with 2 x 4 bit ICs and a 1 bit parity IC.
Posted: 30 Dec 2025 19:00
by LeakyBatz
rubber_jonnie wrote: 27 Dec 2025 23:16
I do have 1mb over 4 256kb sticks which are for Atari's. I get the same results with them. I'll check through my 1mb to see if there are any that non parity
Posted: 30 Dec 2025 19:27
LeakyBatz wrote: 30 Dec 2025 19:00
No worries let us know how it goes.
Posted: 09 Jan 2026 21:53
by LeakyBatz
Thanks @exxos , the diag cartridge arrived earlier this week. I decided to just use 2 256kb sticks until it's running properly.
I set up the cartridge for STE
I'm getting this with a continuous tone...
TeraTerm just shows this "16 Checking exception handling..." message.
Anyone else seen this before? Google AI suggested it might be the MFP chip?
Posted: 10 Jan 2026 11:22
This is the service manual, try section 3 starting at page 25.
BTW did you swap to non parity RAM? If not you should do so.
Atari_STe-Field_Service_Manual.pdf
(3.89 MiB) Downloaded 65 times
!Message from: Moderator
@rubber_jonnie, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Posted: 11 Jan 2026 20:22
by LeakyBatz
Thanks RJ,
I'm using these sticks, I've got 4 of them.
Posted: 11 Jan 2026 23:00
LeakyBatz wrote: 11 Jan 2026 20:22 Thanks RJ,
Can you get a sharper picture at all, I can't read the numbers on the ICs. Either that or write the numbers in a post.
Posted: 12 Jan 2026 18:27
by LeakyBatz
Hopefully this is better
