Page 3 of 4
Re: H5 A3 FIXES
Posted: 28 Oct 2020 17:28
by Icky
Warning #1 - DO NOT SOLDER IN THE 3.3V REGULATOR
Don't solder in the regulator as it is the incorrect part and the pin out is incorrect.
Will update shortly with the right part number.
If you want to use the part in the BOM (AZ1084CD-3.3TRG1) for the 3.3V bus then there is an option to solder it in like so. I bent the legs in the opposite way and soldered. I just modified it to see if the 3V3 bus was working.
- IMG_5862.jpeg (174.33 KiB) Viewed 6428 times
An alternative that will fit correctly is the LM2936Q
https://www.ti.com/lit/ds/symlink/lm293 ... er.it%252F
Re: H5 A3 FIXES
Posted: 28 Oct 2020 22:35
DO NOT SOLDER IN THE DB19 DMA CONNECTOR.. -
A WIP fix... more to come later...
Re: H5 A3 FIXES
Posted: 29 Oct 2020 15:34
Re: H5 A3 FIXES
Posted: 29 Oct 2020 18:13
MONO SELECT FIX
Solder blob pins 2&3 together on the bottom of the PCB.
- mono.PNG (44.96 KiB) Viewed 6427 times
Re: H5 A3 FIXES
Posted: 29 Oct 2020 19:57
by PaulJ
Icky wrote: 27 Oct 2020 15:50
Just checked my board and its the right way round.
Just checked and my ic11 is mounted correctly.
Re: H5 A3 FIXES
Posted: 29 Oct 2020 20:06
by PaulJ
exxos wrote: 27 Oct 2020 23:10
Fix #5 - YM AUDIO BIAS FIX (NO AUDIO)
Remove and blob over C60.
Just checked and my boards don't have the shorted cap. You didn't order yours with extra solder by any chance?
Re: H5 A3 FIXES
Posted: 29 Oct 2020 20:08
PaulJ wrote: 29 Oct 2020 20:06
huh ? C60 is fitted by default.. You removed it and blob over C60 pads..
Re: H5 A3 FIXES
Posted: 29 Oct 2020 20:24
by PaulJ
Well shiver my timbers.... I thought the shorted cap was the issue and here its the solution! :dizzy: :chairsmack:
Re: H5 A3 FIXES
Posted: 04 Nov 2020 11:54
by Steve
With the 3.3v bus vrm: LM2936Q
please could you specify which package? SOIC, TO-252, VSSOP or SOT-223.
Thank you.
Re: H5 A3 FIXES
Posted: 04 Nov 2020 12:37
by DoG
Steve wrote: 04 Nov 2020 11:54
please could you specify which package? SOIC, TO-252, VSSOP or SOT-223...
TO-252 is the footprint for the old part, so I guess the same.
