Page 16 of 26
Re: Phil C's Raven build
Posted: 04 Jul 2025 12:30
by PhilC
@DoG I like smt stuff until it gets smaller than 0805. It takes so long to bend resistor legs etc with TH.
Posted: 04 Jul 2025 13:13
by PhilC
Just going to build up my Eiffel adaptor board today and will have 4 spare board if anyone in the UK would like one. I've also got some CH559 chips too if needed.
Posted: 04 Jul 2025 14:19
by PhilC
Well that's the board built.
Could someone please tell me what I will need to program the CH559. Thanks very much.
BTW, I'm presuming that PO5&6 are the solder points for the bodge wires to the Raven motherboard?
Posted: 04 Jul 2025 15:30
by agranlund
PhilC wrote: 04 Jul 2025 14:19 Could someone please tell me what I will need to program the CH559. Thanks very much.
Instructions for programming can be found here:
https://github.com/agranlund/raven/blob ... /README.md
You will need a usb cable to connect your PC to USB0 on the ckbd for programming it.
USBA:male to USBA:male can be a bit hard to find so you might need to get inventive :)
I went with a USBA:male to USBC:male cable + USBC:female to USBA:male adapter
Bodges (if you are interested in anything they bring) can all be done fairly easy on the back side of the Raven board:
https://github.com/agranlund/raven/tree ... rades/ckbd
I took mine out of the case yesterday and did those and can confirm the right mouse button works for legacy mice in the Joy0 port.
But I haven't yet done the code for reading CPU temperature, powerbutton state, or for shutting down the computer from software.
(PO5&6 are unused. They're footprints for pulldown resistors that could perhaps in the future act as some kind of hardwired config for the firmware)
Posted: 04 Jul 2025 15:36
by PhilC
Thanks @agranlund, I'll have a go at the programming a little later on.
Posted: 04 Jul 2025 15:58
by mrbombermillzy
Phil, slightly off topic, but as you mentioned the eiffel...
did you ever get round to making up one of those C64 to PS/2 keyboard (C= key adapter?) boards?
Posted: 04 Jul 2025 16:54
by PhilC
mrbombermillzy wrote: 04 Jul 2025 15:58 Phil, slightly off topic, but as you mentioned the eiffel...
I did for myself but could make a second if you want one?
Or actually thinking about it, I have a C128 keyboard I am adapting for my C128D so won't need my adapter soon.
Posted: 04 Jul 2025 18:32
by mrbombermillzy
No worries. :)
I was unsure if you had made one up for me (in my DTV thread you mentioned building some). In which case I would have paid for it.
Posted: 04 Jul 2025 18:41
by PhilC
mrbombermillzy wrote: 04 Jul 2025 18:32 No worries. :)
Ok fair enough. I have all the bits to make one, just never did with everything that happened last year.
Posted: 05 Jul 2025 20:50
by PhilC
Got the Eiffel replacement board programmed just now. It's the same process as @arkadiusz.makarenko used with his MSX board, so I had everything to hand and already installed.
Works fine with the existing PS/2 stuff and I'm now off to see where I left my USB keyboards and mice.
