Recently on this thread I talked about designing my electronic load. I want a "not burning hot" dissipation, and assemble little modules ( scaling and offsetting the dac output from a microcontroller to command the gate of the mosfets ; scaling and offsetting the voltage output of a current sensor to feed an adc to that same micro-controller ; the connector circuit to the device under test, with a 3A fuse and the current sensor) because I want to distribute the cost of pcb over time, and eventually reuse modules to have, for instance, 2 independent current sinks, one for a 5V rail, another for a 12V rail *wink* ;)
I have studied the load explained on eevblog #102...
...and another one by Great Scott...
...and then I learn about so called "logic level" mosfets and "rail-to-rail"/"full swing" op-amps, and relearned about op-amps generally.
Today I received the first prototype pcb of the so called "Voltage Controlled Current Sink", a grandiose name for a pair of mosfets attached to their heatsink, and a pair of connectors positioned in symmetry to allow more freedom to assemble with the other part (still in the drafting notebook).
I will revise it a little, as I finally do not like so much having one single connector for each 3A lines, so I will divide into 3 connector each. And now that I see it, my copper plane for the sources of the fets looks a little bit silly near the mosfet. The mounting holes are also a bit to close from the edge.
Re: Sporniket's log on hardware stuff
Posted: 26 Oct 2021 21:01
Be interesting to see how it goes :)
I'm using a 300watt 22R rheostat for my testing so far :)
Posted: 27 Oct 2021 04:55
by sporniket
exxos wrote: 26 Oct 2021 21:01
Yes, I remember having read that one of your testing got your rheostat glowing red.
Thanks for the interest, gives me one more reason to finish :)
Posted: 31 Oct 2021 19:50
by sporniket
This last week-end before payday, I reworked the pcb of my current sink ; as I told, I divided the high-current ports into 3 connector each, and the DUT- entry is re-labeled 'GND', that I have forgotten in my head, comparing to the schematic on eevblog. Before connecting to DUT+, one will have to add the current sensor (I will use one of those https://fr.aliexpress.com/item/1005001698417485.html, the 20A version) and a fuse.
I also work on the circuit that convert a DAC output (e.g. 0V to 3.3V) into a small range ( 0 <= Vmin to Vmax <= VCC ) to the mosfet gate, and then the circuit that convert the voltage of the current sensor ( from VCC/2 to VCC/2 + 0.1V per amp) into the range 0V to Vmax<= VCC for an ADC input. I thought to have 1 board for each circuit, but components are so tiny that it fit in the planned 5cm×5cm board.
Here are the schematics, for those that are interested...
One of my goal is to power my H5 with this type of USB-C PD module :
Of course I will need a proper USB-PD wall plug (up to around 60W to be extravagant, but 30W would be enough) and a proper cable. And I don't plan to power the 12V rail.
At first I want to use the basic 5V@3A, hopefully as is. Then, as I add some upgrade, I may have to use higher voltage (9V or 12V), thus needing a converter circuit. The overall goal is to have a very small footprint, to get rid of the metal plate, replaced by a 3D printable armature for support, or just some nylon spacers, to free most of the space over the area usually covered by the legacy psu.
Posted: 08 Nov 2021 15:18
by sporniket
With my latest sessions of work, like here, I've grown fed up with my current soldering iron (a basic one, 25W, no temperature setting). I planned to wait 6 monthes-1 year before having one of those TS100 or alike, because I prioritize a good enough scope for this Xmas.
I always disconnect the earth on my soldering iron because it causes more damage otherwise.
Posted: 08 Nov 2021 15:44
by sporniket
exxos wrote: 08 Nov 2021 15:27
Ha, so finally it will be an advantage instead of a drawback :) (anyway I didn't planned to touch the tip when it's live :D )
edit : reformulation.
Posted: 08 Nov 2021 20:38
by olivier.jan
If you haven’t ordered yet, I would really recommend getting a Pinecil instead : similar to TS100, but can use USB-C and only 24USD. I’ve been using it for a few months, and it’s really awesome for the price.
And if you are in «Region Parisienne » and want to test, feel free to PM me. https://pine64.com/product/pinecil-smar ... ring-iron/
