Page 11 of 34
Re: Sporniket's log on hardware stuff
Posted: 10 Aug 2021 18:34
So how close is the routing to the original STE ? I'm thinking maybe it could be seen exactly how Atari did the grounding around the DMA to CPU areas...
Posted: 10 Aug 2021 19:51
by sporniket
@exxos , for all traces except grounding, I try to keep the same relative position between traces and components. Meaning if trace A goes between B and C on the real mother board, it will be the same on the motherboard, 90% of the time.
A picture to illustrate, here is a close up of the component side around the GSTMCU, and the result of my work :
So you will get a rough idea of through which area a signal goes between CPU and DMA, but I don't know if it will be of help to you. I am quite sure that if someone make a build from my PCB, it will be mostly luck that it works. At least there should be no short.
For the grounding I am cheating with 2 inner ground planes. On the real motherboard, I can see that any unoccupied space of the board constitute grounding.
Posted: 10 Aug 2021 19:54
No big deal anyway :). Glad you're doing away with those right angles at least :thumbup:
Posted: 10 Aug 2021 20:15
by sporniket
exxos wrote: 10 Aug 2021 19:54 Glad you're doing away with those right angles at least :thumbup:
At least one thing that I'm doing right :)
Posted: 12 Aug 2021 17:26
by sporniket
The routes are all done, now I am working on the copper fillings, meaning also the separation of analog parts. There are 2 analog areas, the sound and the video. Like the traces, I loosely follows what I see on my motherboard.
I left some disclaimers on the silkscreen...
Anyway, the front side is done.
I hope to make a new release candidate by next week. Then I plan to add comments about some fixes that would be helpfull and their references ( #mandatoryFixes :D ).
Anyway, doing a complete PCB proved to be a valuable tool to proofread my schematics.
edit : the github repository is up to date, as usual. (see my signature for the repo).
Posted: 12 Aug 2021 18:03
by DoG
Well done! Looks really nice.
Posted: 12 Aug 2021 18:08
by sporniket
Yes, it is very satisfying in itself :)
Posted: 12 Aug 2021 21:24
by sporniket
The back side now.
Now it's time to tidying things before release...
Posted: 13 Aug 2021 13:37
by sporniket
Today I am working on the Lynx 2 that is still running, but with a screen too bright and around 7V at C41, and non working off-on, the only way to put-remove batteries.
Before that, I assembled a battery holders for easier testing when the console is opened :
Now, back on this "still running Lynx", I had noticed a suspicious bodge wire :
It turns out that it is a mode using the headphone pins to bypass the voltage regulator circuitry, so I removed it -and reflowed the solder joints-.
Side note : I can now compare non-leaded vs leaded solder handling, and now I understand all the frustration I read here and there regarding non-leaded solder. With leaded solder, I became magically good at soldering, and at using the solder wick. I guess that my faithful 25W-entry-level soldering iron and its pointy tips, while totally suitable for leaded solder, are barely suitable for non-leaded soldering (especially on pads connected to ground or large copper areas...)
Then I prepared to for testing...
... And nothing happens :( . A close look at the mother board, I can see that it is brownish around Q8, so next time I can make an order to mouser, I will try to replace that transistor.
Posted: 15 Aug 2021 08:43
by sporniket
The last -hopefully- release candidate before the real one.
https://github.com/sporniket/kicad-conv ... /1.0.0.rc4
This release includes :
  • A standalone Kicad project (all custom libraries included and ready to use)
  • A PDF of the schematics
  • A PDF of the silkscreen
  • A small gallery
The schematics seems complete and free of errors, thanks to making the pcb. I also mentionned some hardware fixes (with related urls), only related to the schematics and "easily" doable (changing a soldered PLCC CPU is not "easy" for me) :
  • DMA pull-up on databus (done on the floppy disc controller U301)
  • WD1772 pull-ups (done on U305)
  • LMC audio mix fix (done near U508)
  • RGB Video ghosting fix (done at C411)
