Page 2 of 2
Re: Kodak80 H4F build
Posted: 29 May 2025 21:45
by kodak80
Good spot. Changed and boots to a green desktop now. :)
Posted: 04 Jun 2025 11:04
by kodak80
Okay, now some tests.
External Hard disk: tested and working :)
Internal Hard disk (20 pin): tested and working :)
Internal Hard disk (24 pin): untested
Internal Floppy: not working - drive motor activates, keyboard and floppy LED light up but nothing happens after that :(
External Floppy: not working - same result as internal drive :(
YM audio output: tested and working :)
MIDI output: tested and working :)
MIDI input: untested
Mouse: tested and working :)
Keyboard: tested and working :)
Video output 13 pin DIN: High res: tested and working :)
Video output 13 pin DIN: Low/Medium res: tested and working :)
Video output VGA: untested
Serial: untested
Parallel: tested and working - tested with PARCP USB file transfers :)
RTC: untested
Cartridge port: untested
4x Expansion ports: untested
Blitter: untested
Boot TOS rom: tested unjumpered: boots to TOS :)
Boot TOS rom: tested jumpered: not working but might be my dual rom - further testing needed
Gembench test results:
Posted: 07 Jun 2025 03:07
by kodak80
Paralell port now tested and works fine. List in previous post updated.
I have replaced the WD1772, DMA and Yamaha chips but floppy still not working. Motor activates on drive but nothing after that.
Posted: 07 Jun 2025 08:56
Have you checked the 1772 clock to see if 8mhz is there?
Also your AB swap jumpers look wrong.
viewtopic.php?t=2785
