Page 2 of 2
Re: FALCON030 which only boots on ROM
Posted: 09 Oct 2022 20:18
by ylf22300
stephen_usher wrote: 09 Oct 2022 08:19 Before you fit the clock patch run the tests to see if you actually need it in the first place. My machine didn’t.
What kind of tests must be run ? a specific software ?
Posted: 09 Oct 2022 22:00
by stephen_usher
There's the ACE Tracker which seems to push the system to the limit and this tool which apparently Atari used to test machines after they'd patched machines.
Posted: 11 Oct 2022 11:55
by Dlfrsilver
Beware, on mine, it seemed at first to not be needed, and finally, i have discovered that there was file corruption happening without warning !
So in the end, i have installed Exxos clock patch, and then, no more corruption, the machine operates normally.
Posted: 11 Oct 2022 15:14
I think its also worth noting that you can't take the tests as gospel. They are very dependant on a full moon/ alignment of the planets, ritual chicken sacrifice and what side of your bed you got out of in the morning etc
