Page 2 of 3
Re: My first TF536
Posted: 22 Jan 2021 13:23
by alenppc
go0se wrote: 21 Jan 2021 20:53
8 Bit Dreams wrote: 21 Jan 2021 20:20 Wow! Hopefully You was prepared to see fireworks on power on, since these are four-layer boards. Cutting them may short out GND and VCC inner layers.. :shock:
Where's your sense of adventure?? :lol:
I mean, it says "terrible fire" right on it :lol:
Re: My first TF536
Posted: 22 Jan 2021 18:42
by Lynxman
Seriously though. There are no traces there, just ground and voltage planes, and they are easy to see at the cut edge. I will put a piece of kapton tape over the edge before I install the RF shield so that there's no chance the shield will touch the layers at the edge.
Re: My first TF536
Posted: 23 Jan 2021 02:22
by Lynxman
I built an IDE68k today for my A2000 and tried it in my A500+ first. Booting from SD is much quicker than with TF534 or 536. I built this: https://www.pcbway.com/project/sharepro ... plica.html
Booting to WB with CF with my TF536 takes 17 seconds, which is pretty quick. I'll time the IDE68k later...
IDE68k boots to WB in 13 seconds. The same image takes over 40 seconds with my TF536 (one of the slow booting cards. See next post).
Re: My first TF536
Posted: 23 Jan 2021 03:07
by Lynxman
BTW. Different SDcards take different times to boot even if they have the exact same image on them. What's doing that? With some SD cards I try it takes 20 seconds for it to start doing anything (led activity) while others are instant. Repeatable even when I reinstall freshly to the different cards. Same maxtransfer setting. I have done a huge amount of comparisons. KS3.1 There's more to SD cards than we have control over.
I'm gonna sell my A500 with one of my TF534 now that I have the 500+ and to make the user experience as good as possible I tried all my SD Cards lol and ended up with a 2 GB card that boots in 20 seconds with full WHDLoad and patches.
Re: My first TF536
Posted: 23 Jan 2021 05:00
by Maximilian
Lynxman wrote: 23 Jan 2021 03:07 I tried all my SD Cards lol and ended up with a 2 GB card that boots in 20 seconds with full WHDLoad and patches.
Could you share the manufacturer, type and size of that one?
I would be interested to know what makes that one so special.
Re: My first TF536
Posted: 23 Jan 2021 11:46
by PaulJ_2.0
Lynxman wrote: 20 Jan 2021 18:02 Yes. I originally built that red RAM expansion for my A500, and when I got this A500+ I moved it over the the A500+ because it has room for another ram chip to give 1 MB extra chip ram. I then put another old school expansion that only could have 512 kB in my old A500. I omitted the motherboard battery because of the clock on the ram board and it seems to work fine. It's more practical to have battery access from the expansion bay anyway.
I was more wondering how it works, do they not conflict?
Have you disabled the onboard RTC?
Re: My first TF536
Posted: 23 Jan 2021 16:33
by Lynxman
Maximilian wrote: 23 Jan 2021 05:00
It's an old Sandisk with a strange sticker on it saying "Easy Going". I don't remember what it came in. Probably an old GPS. It has SanDisk stamped in the back which is how I know it's Sandisk. I have another Sandisk Extreme III 2GB which has higher transfer speeds but still bootsmuch slower. It takes 20 seconds before any activity happens with it. There's something in these things causing them to act differently.
I have ordered a different IDE to SD adapter which was more expensive which might change things too.
Re: My first TF536
Posted: 23 Jan 2021 17:09
by Maximilian
For the PC I modded some CF adapters a long time ago to enable PIO 4 etc., that made a lot of difference.
Re: My first TF536
Posted: 23 Jan 2021 21:19
by Lynxman
PaulJ_2.0 wrote: 23 Jan 2021 11:46
Not sure. I haven't paid much attention to the clock. Guess it would be a good idea to disable the one on the expansion.
Re: My first TF536
Posted: 23 Jan 2021 21:27
by Lynxman
Maximilian wrote: 23 Jan 2021 17:09 For the PC I modded some CF adapters a long time ago to enable PIO 4 etc., that made a lot of difference.
What's involved in that mod?
