Page 2 of 3
Re: Scandoubler /Flicker fixer
Posted: 16 Oct 2020 10:47
by GadgetUK164
terriblefire wrote: 16 Oct 2020 08:19
GadgetUK164 wrote: 16 Oct 2020 00:07
It's open source by the looks of it. I was going to try and order it but unfamilar with how the gerber files are structured and named there. DirtyPCBs seems to like everything having a .gbr extension with a seperate extention for the drill files and the cuts file. At the bottom of that page is the link to the bom and gerbers (in one zip on aminet).
Just ordered 5 PCs. Will send you one when they arrive.
Design of the board looks good. I think i might be able to improve on the CPLD firmware.
EDIT: Only thing i would change about the board is to make it 4 layer.
Wow, that's awesome!!!
Posted: 16 Oct 2020 10:59
by terriblefire
GianDO wrote: 16 Oct 2020 10:10
It will also be well made, but if you see half the screen ...
Then i will fix the firmware.
Posted: 16 Oct 2020 11:05
by GianDO
terriblefire wrote: 16 Oct 2020 10:59
so the fact that it doesn't show full screen is just a matter of firmware?
Posted: 16 Oct 2020 11:10
by terriblefire
GianDO wrote: 16 Oct 2020 11:05
not 100% known but thats usually down to vga timings.
Posted: 16 Oct 2020 12:13
by GianDO
terriblefire wrote: 16 Oct 2020 11:10
If it worked correctly it would be a great alternative to the other more expensive and hard to find scandoublers. Also because it seems to me that there are not many alternatives around ..
Posted: 16 Oct 2020 12:20
by terriblefire
GianDO wrote: 16 Oct 2020 12:13
Personally I have not been interested in these kind of scandoublers because external ones are so good. Generally I want to use Amiga on standard TV.
Posted: 16 Oct 2020 12:27
by GianDO
terriblefire wrote: 16 Oct 2020 12:20
But can you get high resolutions even on standard TVs?
Posted: 16 Oct 2020 12:32
by terriblefire
GianDO wrote: 16 Oct 2020 12:27
Its never been something i wanted to do on Amiga
Posted: 16 Oct 2020 13:01
by GianDO
terriblefire wrote: 16 Oct 2020 12:32
Ok, instead on my amiga 2000 I have a Picasso II and I would like to use it, but at the same time I would like to display the standard amiga resolutions without having to use two monitors ..
Posted: 06 Mar 2021 15:11
by 8 Bit Dreams
You should get one of Mazes Flicker Fixer cards, then
- 16068119288941032521005.jpg (236.8 KiB) Viewed 4166 times
