Page 2 of 3
Re: My TF536 build failure
Posted: 11 Sep 2020 17:55
by amimjf
There was a BOM posted in another thread, whats listed there is;
CTS CB3LV-3C-100M000000
i will order some.
Posted: 11 Sep 2020 21:49
by Lemaru
Just a heads up, that's the same oscillator I got from digikey for both of my boards and they both work fine.
It's also the same one listed in the bom_TF536.csv file over on this thread
https://www.exxosforum.co.uk/forum/viewt ... 728#p38246
- Screenshot_2020-09-11-21-45-12-39.jpg (90.08 KiB) Viewed 4970 times
Posted: 12 Sep 2020 08:08
by amimjf
I was pretty sure I used that original CSV BOM when I did my digikey order. I guess either it's not delivered to spec, faulty or I've fitted it wrong.
Do you have a photo to confirm orientation ?
Posted: 12 Sep 2020 09:18
by LADmachining
amimjf wrote: 12 Sep 2020 08:08
The orientation looks OK with the dot on the oscillator nearest to the dot on the PCB.
If you ordered that oscillator and didn't specify a frequency for it during check-out, Digi-Key would supply it unprogrammed and it will not produce the expected output. The clue to look for is where it is shown as a 'Value added item' in the search results. On the actual product page under product attributes, there is a notification of 'Programmed by Digi-Key'.
Not sure why this oscillator is specified when there are loads of fixed-frequency ones that are suitable, removing another possible 'gotcha'.
This BoM is based on the original TF BoM, my working boards and feedback from others during their builds...
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Anthony
Posted: 12 Sep 2020 09:42
by PaulJ_2.0
Ah crap sorry guys I didn't mean to cause all this confusion.
I checked the first part of the part number and noticed it was programmable and then after checked the full part number and it is indeed the correct part programmed to 100MHz.
It could still be at fault, but the part is correct.
Posted: 12 Sep 2020 10:31
by amimjf
Thanks all,..
From my order it links to "SIT8008BC-83-33E-100.000000T",.. that looks like its pre-programmed,.. unless i missed an obvious step during ordering.
Will grab a scope on Monday from the office.
- two.png (146.54 KiB) Viewed 4921 times
- one.png (54.08 KiB) Viewed 4921 times
Posted: 14 Sep 2020 19:30
by amimjf
Hi,
Using a scope I can see a waveform off pin3 of the oscillator, my scope only does 70mhz though.
Pin94 of the CPLD (CLKCPU), is showing at 50Mhz on the scope,.. it looks a bit weird, but i guess i've got it setup a bit wrong.
To my simple eyes that looks like the clock is not the issue.
What else could i check ?
- IMG_20200914_192425.jpg (283.17 KiB) Viewed 4867 times
Posted: 14 Sep 2020 19:41
by amimjf
DTACK (pin10 on 68k) is high
AS (pin on 68k) is high
030 is warm (not hot) to the touch, as is the CPLD.
030 does smell is bit, but i might just be bit over-sensitive.
Posted: 14 Sep 2020 19:49
by amimjf
AS (pin6 on 68k) now alive (at 1.7Mhz apparently)
DiagROM started Blue, then stuck on Red.
- IMG_20200914_194537.jpg (246.13 KiB) Viewed 4851 times
!Message from: Moderator
@amimjf, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
Posted: 14 Sep 2020 20:00
by amimjf
Pushed the 68k socket in firmly and got Cyan screen....
Illegal Instruction - Red/Cyan
What serial port does diagrom send its RS232 output on an A2000 ?
