GAL programming conundrum.
Posted: 11 Nov 2026 21:33
Here's a problem:
A set of signals select the enable for an output.
Later another signal pulses high then low after this is enabled.
The output selected must then be disabled on the falling edge of the second signal. The state is reset when the selection terminates.
How would I go about doing this using an ATF16V8B GAL?
It would have to go into register mode I would imagine.
Any experts here?
Any experts here?
