Page 1 of 1
MISSING LINK TUTORIAL - DEANO (From MEGA ISSUE 3)
Posted: 22 May 2018 18:17
MISSING LINK TUTORIAL (PART 1)
BY DEANO
(eds note....it's probably worth mentioning that this tutorial is more for the experienced stos programmer than the beginner, although learners may still find it of interest....enjoy!)
The Missing Link is, in my opinion, the best extension to be written for STOS. It covers a lot of areas of STOS programming including a set of extra commands plus better faster versions of old ones....
In this tutorial I shall take you step by step through the commands explaining in detail how to use them. Although Top Notch have given a fair idea of how to use the extensions new commands there are still a few of you who need that extra bit of help....
This month we shall have a look at the new SPRITE commands...
BOB X1,Y1,X2,Y2,0,1
BOB SCR,ADR,IMAGE,X,Y,0
JOEY X1,Y1,X2,Y2,0,0,1
JOEY SCR,ADR,IMAGE,COLOUR,X,Y,0
H=B HEIGHT (ADR,IMAGE)
W=W HEIGHT (ADR,IMAGE)
The BOB command is a new version of the SPRITE command. It is much faster and smoother, and theres no limit to how many you can have on the screen at the same time. This is a new method of sprite movement known as Pre-Shifting, and although it takes up more memory than normal sprites, it is much better. The format of this command is.....
SCR is the screen to place the BOB on. Note that unlike SPRITE which is only displayed on the physic or logic screen, a BOB can be displayed on either the BACK screen, the PHYSIC screen, or even the LOGIC screen. It can also be placed in a memory bank.
ADR is the memory bank where the BOB's are held. Unlike sprites that can only be accessed from bank one, BOB's can be loaded into any bank. Note that we need to use the START command to tell STOS which bank the BOB's are in. So if the BOB's were loaded into bank 5, the varible ADR would be 'start(5)' and not '5' as we use with commands like 'screen copy'.
IMAGE is the number of the BOB to display on screen which ranges from nought to the number of bobs in the bank. It's important to remember that when you convert your sprites to bobs, the image numbers are moved back by one place. So the first sprite would become BOB 0, the second would become BOB 1, and so on.......
X and Y are simply the X and Y co-ordinates of the BOB. Note that unlike sprites, the hot spot for a bob is best being put in the top left hand corner. So the BOB is placed on the co-ordinates of the hot spot.
The last number (nought) does'nt do anything yet, it's just there for future purposes so you can leave it at nought.
This command is a new version of the LIMIT SPRITE command, only it limits a BOB to a certain part of the screen. To limit the bob means to set up an area on screen where the bob is to be visible, if it moves outside this area then it will vanish. Try this routine...
10 key off : hide : curs off : mode 0
20 load"bob.mbk",5
25 A=palt(start(5))
30 box 50,50 to 150,150
40 bob 50,50,150,150,0,1
50 logic=back
60 XB=60 : YB=60
70 repeat
80 XB=XB+2
90 bob logic,start(5),0,XB,YB,0
100 wait 5
110 screen swap : wait vbl
120 until XB=170
130 goto 60
This routine will draw a box on screen and move the BOB to the right by steps of two pixels. Note that when the bob moves out of the box it starts to vanish. This could be used to great effect in games. As you can see, the co-ordinates of the box are the same as those of the limiting version of BOB meaning keep the bob between these co-ordinates.
The next command is the JOEY command. This command is simular to the BOB command only its used for sprites which are only one colour...for example, a white bullet sprite. The format of the command is...
The parameters of this command are the same as the BOB command, with the extra parameter called COLOUR. This is the number of the colour in the present palette that the joey is...for example, if the joey was white, and white was colour number ten in the palette then COLOUR would be ten. For unknown reasons, colour fifteen is the fastest.
This version of the command limits the joey to a certain part of the screen. It just the same as the BOB version only the two noughts are reserved for future use.
The last two commands are B WIDTH and B HEIGHT, the format is.....
W=b width (ADR,IMAGE)
H=B height(ADR,IMAGE)
These commands return the size of a bob, in pixels. ADR is the number of the bank where the bob is stored and IMAGE is the image number of it.
EXAMPLE:-
10 key off : curs off : hide : mode 0 20 load"bob.mbk",5 30 W=b width(start(5),0)
40 H=b height(start(5),0)
50 print"This bob is ";W;" pixels across"
60 print"This bob is ";H;" pixels down"
70 print"Total size is ";W;"X";H
This command would be useful in finding out the size of a bob so we can calulate if it will fit on a certain part of the screen.
DEFINING BOBS AND JOEYS
If you look at the MAKE program, you'll see that the options to convert bobs and joeys ask how many images it should make of each sprite. Well the smaller the number, the less memory used, and the smaller the converted BOB bank. If you set the program to make eight images of a sprite, then they will move quite smoothly if you move them at two pixels at a time. Lower numbers mean you would have to move them in bigger steps in order for them to move smoothly. The same applies to JOEY's, although, these would normally be used as bullets which need to be fast so you can make about two images of each one.
Well thats the end of the first part of this tutorial and I hope I've managed to make the SPRITE commands more clearer to you. Next month we shall have a look at the Mapping commands.
Till next month..........DEANO
(another ed's note.......if you haven't got the missing libnk extension, then why haven't you got it?!!!. If you want it, you can get it from most p.d. libraries. I have to be honest and say no STOS programmer should be without it.)
Re: MISSING LINK TUTORIAL - DEANO
Posted: 22 May 2018 18:18
MISSING LINK TUTORIAL......PART 2
BY DEANO
Hello again STOSSERS. Welcome to the second part of the missing link tutorial. This month we are going to look at the mapping commands.
WORLD X1,Y1,X2,Y2,0,1
WORLD SCR,BLOCKS,MADR,X,Y,0
LANDSCAPE X1,Y1,X2,Y2,0,1
LANDSCAPE SCR,BLOCKS,MADR,X,Y,0
SETBLOCK MADR,X,Y,BLOCK
R=WHICH BLOCK(MADR,X,Y)
REPLACE BLOCKS MADR,BLOCK1,BLOCK2
R=BLOCK AMOUNT(MADR,BLOCK)
XY BLOCK MADR,XADR,YADR,BLOCK,NUM
X=X LIMIT(MADR,X1,X2)
Y=Y LIMIT(MADR,Y1,Y2)
A=MAP TOGGLE(MADR)
These 'mapping' commands are used for scrolling the screen. Note that you could use 'def scroll' for this purpose but these new command make scrolling a lot easier. For a start, scrolling left and right can be done in steps of less than 16 pixels thus creating smoothy scrolling. It also solves the nightmare of moving sprites across a scrolling background. Right.....lets look at the first command.
The WORLD commands allow you to scroll the screen left, right, up, and down. This version of the command allows you to specify how much of the screen you wish to use as the scrolling area. This is usefull for having the top half of the screen as the scrolling area, and the bottom half as the games scoreboard.
If you've seen how the STOS 'limit sprite' command works, you'll see that the mouse is limited to that part of the screen, its like having it trapped in an invisible box.
This is how this version of 'world' works. It traps the scrolling map in an invisible box. X1 and Y1 hold the start co=ordinates of the screen area to be trapped...in other words the top left hand part of the screen. X2 and Y2 hold the end co-ordinates of the box..IE: the bottom right hand part of the screen. The last two parameters have no meaning as yet so leave them as they are.
In order to create these scrolling areas, known as maps. We first have to define one. We can do this using the EDDY program supplied with the missing link package. This is simular to using the 'Map Definer' supplied with STOS only we don't use normal STOS sprites to create the map. We use the MAKE program to make the sprites into world blocks so they can be loaded into EDDY. Note that even though the EDDY manual tells us that we can load 'world' and 'landscape' blocks into the EDDY definer...we can only load 'world' blocks into it. If I get time I'll do an article on these two programs.
This is the command that actually scrolls the map we defined with EDDY. Note that we need two sets of data installed before we can use this command. These are...World Blocks, and Map Data.
SCR= This is the screen to display the map on, it can be either LOGIC, PHYSIC, or BACK.
BLOCKS= This tells 'world' where our world blocks are, load them into a memory bank and use 'start(bank-number)'.
MADR= The bank number of the map data saved from EDDY, note it must have been saved as 'world data', again use 'start(bank-number)'.
X and Y= The X and Y co-ordinates of the maps starting point.
The nought does nothing as yet, maybe in an update. Anyway, heres a routine that shows the use of the two commands.
10 key off : hide : flash off : mode 0
20 load"BLOCK.MBK",5 : rem load world blocks into bank 5
30 load"MAP.MBK",6 : rem load world map data into bank 6
40 logic=back : X=0 : Y=0
45 world 32,10,288,190,0,1
50 repeat
60 world logic,start(5),start(6),X,Y,0
70 if jleft and X>0 then dec X
80 if jright and X<1500 then inc X
90 if jup and Y>0 then dec Y
100 if jdown and Y<2000 then inc Y
120 until fire
If we look at lines 80 and 100 we see that the program is checking if the X and Y varibles are less than a number thats higher than the co-
ordinates of the actual screen. This is because the varibles are the co-ordinates of the scrolling area of the map and not the screen.
Note that the first version of the WORLD command must have its X co-
ordinates in steps of 16 pixels due to a bug in the ST's registers.
The LANDSCAPE command....
The LANDSCAPE command is exactly the same as WORLD except that it can only scroll its map in two directions. Its only used for games that scroll just up and down. It can't do the multi scrolling that WORLD can do. The parameters are the same as those of WORLD, but the X co-
ordinate cannot be changed in a loop, only the Y co-ordinate. X is just used to set the X starting point of the map to be scrolled.
Note, as with the first version of WORLD, the first version of LANDSCAPE must have its X co-ordinates in steps of 16 pixels. Note that we can use the last routine to see these commands in action. Just convert your sprites to LANDSCAPE blocks, load them into EDDY and make your map making sure you don't go over the X co-ordinate of 304 and make your map downwards, not exceeding the 320 X co-ordinate. Save your map data as landscape data, load your landscape blocks into bank five, and new landscape map data in bank six. Remove lines 80 and 90 and run the program. As we can see, we can only move up and down.
Note, due to the bug in EDDY, we have to make our sprites first into world blocks, then landscape blocks. Load the world blocks into EDDY to make the landscape map, then load the landscape blocks into our example routine. Bit of a pain but there we go.
As you may have noticed, we have being uses these things called blocks, ie: converted sprites, to make the world and landscape maps. So we can now use this command as a form of collision detection. The MADR varible holds the bank number of the map data used by the world and landscape commands, and X and Y are the co-ordinates of the block we're checking for. R holds the block number. So really its like checking for a sprite entering a zone without having to set the zone first. If we look at the screen in EDDY where we select our blocks, we can count along to a certain block to find its number in the row. Note that the row starts from nought to the number of blocks in the row, just like the BOB command. So, if we defined, say a diamond as sprite number one. This would be block number 0.
So what we want to do is place our diamond blocks in certain places of the map as we define it, then tell STOS that when our BOB touches it, to detect a collision, add this line to our example.
105 BL=which block (start(6),XBOB+14,YBOB+12)
The varibles XBOB and YBOB hold the X and Y co-ordinates of the bob, as the bob touches a certain block, the varible BL would contain the row number of it. So, if the bob touched the diamond, then BL would be set to nought. If the bob touched the next block in the row then BL would be set to one. Lets say we defined two sprites has part of the map, and converted them to map blocks. We could use this routine to check which block has been touched. Try these lines...
106 if BL=0 then print"You have found the diamond."
107 if BL=1 then print"You have hit the wall."
Where the wall is the second block in the world/landscape blocks.
Each block in the map is set two either one if it exists, or nought if it does'nt. These means that if a certain block was in the map at co-
ordinates X and Y, it would be set to one, or nought if it was'nt there. We can use this command with WHICH BLOCK to find a block, when its found we can set the block to nought which will then erase the found block off the screen. MADR is the bank number of the map data, X and Y is the co-ordinates to check at, and BLOCK is the row number of the block to remove from screen. Example.....
10 BL=which block(start(6),XBOB,YBOB)
20 if BL=1 then set block start(6),XBOB,YBOB,0 : bell
This command does as it says....it replaces one type of block with another. This is usefull if say, you wanted to change all the diamonds on screen to money bags for example. We can have our diamond block as block one in the row, and the money block as block two, then change the diamonds into money bags like so....
This command is usefull for checking how many times a certain block appears in a map. If we had our diamond and money bag blocks still in the same place, and we put 20 copies of our diamond on the map screen, then we could use this command to find how many diamonds are on screen. Try this example.....
100 DIAMONDS=block amount(start(6),1)
110 if DIAMONDS=0 then print"All diamonds are collected"
So, BLOCK holds the number of block ones..(diamonds) there are in the map. As each one is removed with SET BLOCK, the DIAMONDS varible will decrease by one, line 110 checks if all diamonds have gone.
XY BLOCK MADR,XADR,YADR,BLOCK,NUMBER
If we wanted to store all the X and Y co-ordinates of a certain block in an array....this command will do it. So, if we wanted to set the X and Y co-ordinates of the diamond...(block 1), we would use this little routine....
10 A=block amount(start(6),1)
20 dim XBL(A),YBL(A)
30 xy block start(6),varptr(XBL(0)),varptr(YBL(0)),1,A
40 for X=0 to A : print XBL(X),YBL(X) : next X
XADR and YADR are the X and Y arrays to put the co-ordinates in, BLOCK is the row number of the block we want to get the co-ordinates of, and NUMBER is the total number of block ones found in the map.
This can be used if you had a number of diamonds and you wanted each one to score different points. Using the arrays you can see which diamond block has been collected and update the score with the certain diamonds points....like so
50 if A=1 and XBOB=XBL(1) then SC=SC+40
60 if A=1 and YBOB=YBL(4) then SC=SC+100
These commands imform STOS how large in width and height the map is. X1 is the X start of the map, X2 is the X end of the map, Y1 is the Y start of the map, and Y2 is the Y end of the map. X and Y hold the end co-ordinates of the map. MADR is the bank number of the map data. This can be used to check if a bob is still within the X and Y areas.
M=MAP TOGGLE(MADR)
A nice simple one here. If the data in MADR is world data, then this command will convert it to landscape data, or vise versa...
10 load"map.mbk",6 : rem World data
20 N=map toggle(start(6))
30 print"The world data is now landscape data"
40 N=map toggle(start(6))
50 print"The landscape data is now back to world data"
This is usefull if you had some levels in your game that use the landscape command, and some that used 'world'.
Well thats the end of part 2, see you in part 3 next month where we shall have a look at the text commands.
Re: MISSING LINK TUTORIAL - DEANO (From MEGA ISSUE 3)
Posted: 22 May 2018 18:20
MISSING LINK TUTORIAL........PART 3
BY DEANO
Welcome to part three of the missing link tutorial. If you've missed
the first two parts then they can be found in issues 9 and 10.
Well it looks like its going to be an easy tutorial this month as we
are looking at the TEXT commands...theres only two!!!
text SCR,FONT,TEXTADR,X,Y
TEXTADR=string(NUM)
The TEXT command is quite simply a replacement PRINT command. It has
a number of advantages over PRINT. It only prints text on one
bitplace which makes it faster than PRINT. It can be printed on any
screen or memory bank. It can use other fonts without using a window,
and you don't need to use the LOCATE command as it has one built in.
The format of the command is......
SCR:-The address or bank number to display the text.
FONT:-The FONT to print in......this can be the normal STOS default
character set fonts or a font bloaded into a bank. Values 0 to 2 are
the default LOW/MED/HIGH RES fonts in STOS, and 3 onwards is a bank.
TEXTADR:-Unlike PRINT, we can't just print a normal string or number,
we need to put it in a varible first. So TEXTADR is the varible name
which contains the string or number.
X & Y:- The X and Y postion of the text in text co-ordinates.
Lets have a look at what it can do. We'll use it to print a message
on the screen, so we put the message in a varible.
10 T$="STOSSER.....The only monthly STOS diskzine."+chr$(0)
Now we use TEXT to print it on the screen.
20 text logic,0,varptr(T$),2,10
Note the use of the VARPTR command.....this is because the TEXT
command needs to find out the address of T$ before it can print it.
Note that in order to use a string varible with TEXT we must add a
CHR$(0) at the end....but not with number varibles.
Run this program, and the message in T$ will be printed on the
LOGIC screen with the LOW RES character set (FONT) at co-ordinates
2,10. Now lets print in a newly defined font.
First we install our extra character set into bank five in the normal
way by either using the QUIT AND GRAB option from the Font Definer or
using this line.
reserve as set 5,2322 : bload"newset.mbk",5
Now simply replace line 20 to......
20 text physic,3,varptr(T$),2,10
Remember that font 2 is the HIGH RES default character set in STOS so
in order to use one from a bank we change it to 3. Note that we've
also changed the command to print T$ on the PHYSIC screen.
We can easily change the command to print T$ on a screen stored in a
memory bank by simply reserving a bank as a screen in the normal way
then changing SCR to 'start(bank number)'. EG:-
15 reserve as screen 5
20 text start(5),0,varptr(T$),2,10
Although the above example will print a string of text. We can't
directly use it to print a number. So what we need to do is define
a number varible then convert it using the next command.
TADR=string(number varible)
This command is a new faster version of the STR command. As TEXT only
prints a string varible we need to convert the number varible to a
string varible. Look at the following program.
10 T=12345
20 TADR=string(T)
30 text logic,0,TADR,2,10
Line 10 puts the number 12345 into the 'T' number varible. Line 20
puts it in the TADR varible as a string varible. And line 30 prints
it onto the logic screen. Note the absence of VARPTR. We don't need
it to print a number as the STRING command has alreadly found the
address of the newly converted string.
Thats it for this month, and I'd just like to close in pointing out
that the TEXT command has a large bug. You can only print in one pen
colour.....therefore using the PEN command has no effect on the
printed string. I can't find any way around this so hopefully this
bug will be fixed in the next update.
Next Month.........the miscellaneous GFX commands.
Posted: 22 May 2018 18:21
MISSING LINK TUTORIAL PART FOUR
BY DEANO
Well here we are again.....are you all ready for this. The exciting,
the only, the sweaty, part four of the missing link tutorial. In case
you've missed the previous issues of STOSSER we're going though all
the commands of this extension step by step giving a better clearer
explanation. This month......the Miscellaneous GFX commands.
wipe SCREEN
tile SCR,TADR,IMAGE,X,Y
mozaic SCR,TADR,IMAGE,X1,Y1,X2,Y2,X,Y
spot SCR,X,Y,COLOUR
reflect SCR1,Y1,Y2,SCR2,Y3
wash,SCR,X1,Y1,X2,Y2
blit SCR1,X1,Y1,X2,Y2,SCR2,X1,Y1
m blit SCR1,X1,Y1,X2,Y2,SCR2,X1,Y1
Well I had an easy time last month....but it seems thats not going to
happen this month. It took me ages to get the hang of that reflect
comand.....anyway, lets get on with it shall we!
WIPE scr
A nice easy one to start off with. The WIPE command is a new version
of CLS. Its advantage is speed, its much faster than CLS, in fact
about twice as fast. The varible scr can be the back, physic, or
logic screen. It can even be a memory bank. The command works in the
same way as CLS with the ability to clear any screen or bank.
TILE scr,tadr,image,x,y
This one scrolls a wall of sprites in different directions on the
screen. In fact it was used in earlier STOSSER shells. Its also used
by various demo coders. The command draws a wall of tiles which are
converted sprites onto screen SCR. The TADR parameter is the memory
bank where the tiles are held. IMAGE is the sprite number you wish to
build into a wall and x and y are the screen co-ordinates to start
the wall from. Note that like bobs the images in a tile bank start
from nought instead of one. So if you wanted to use sprite one in
your sprite bank then you would pass image as nought. When the
sprites are converted to tiles using the MAKE program then all the
images are moved back one place, so sprite one becomes tile nought,
sprite two becomes tile one and so on. Note also that the sprites
must be 16x16 in size and this version of the command fills the whole
screen with the wall of tiles.
EXAMPLE:
10 key off : hide on : curs off: mode 0
20 for X=1 to 300
30 tile logic,start(5),0,X,0
40 next x
MOZIAC scr,tadr,image,x1,y1,x2,y2,x,y
This is another version of the TILE command. Only this one allows you
to limit the wall to part of the screen instead of using all of it.
The parameters are the same as TILE but with the extra x1,y1,x2,y2.
X1 and Y1 are the top left hand of the part of the screen and x2,y2
are the points down to the bottom right hand corner. In other words
this limits the tiles to the part of the screen between X1,Y1 and
X2,Y2. This works just like the LIMIT SPRITE command.
SPOT scr,x,y,colour
Another easy one this.....SPOT is a new PLOT command, it is faster
than PLOT and it allows you to plot a point on any screen in any
colour. SCR can be any screen or memory bank, and COLOUR is any
colour between 0 and 15 in the present palette.
EXAMPLE
10 rem FILL THE SCREEN WITH DIFFERENT COLOURED DOTS
20 key off : hide on : curs off: flash off: mode 0
30 repeat
40 I=rnd(14)+1
50 X=rnd(319) : Y=rnd(199)
60 spot logic,X,Y,I
70 until mouse key
REFLECT scr1,y1,y2,scr2,y3
I hated this one, it certainly took a while to get the hang of it.
Once I did get the hang of it I found it quite easy. Anyway, what the
command does is produce either a 'mirror' effect, or a 'rippling
water' effect depending on how you use it. Now, unlike commands like
screen copy and box which allow you to grab part of the screen by
certain x and y co-ordinates.....the REFLECT command only uses y co-
ordintates. The Y co-ordinates actually mean 'pixel lines', if you
draw a line using DRAW 0,0 to 319,0 then you'll get a straight line
across the screen. This is what I mean by pixel line. SCR1 can be
either a screen or memory bank containing the picture of which you
wish to reflect part of, and SCR2 is the screen to place the
reflection on. In order to explain this command a little better I am
going to use a diagram.
Y1 ______________________________________________________________
This is the part of the picture to reflect
Y2 ______________________________________________________________
As we can see, the REFLECT command does'nt use X co-ordinates. The
pixel lines start at Y co-ordinate Y1 and finish at Y co-ordinate Y2.
So the part of the picture inside these lines is the part we are
going to reflect.
Y3 is the pixel line where we want to place the captured screen.
Y3 _______________________________________________________________
Place the captured part of the picture here
Now look at this example......
10 key off : hide on : flash off : curs off : mode 0
20 reserve as screen 7
30 load"PIC.PI1",7
40 rem
50 rem Grab part of the picture in bank 7 between lines 50 and 100
60 reflect start(7),50,100,logic,140
70 rem The picture is placed on pixel line 140
If we run this program we will see that the part of the picture we
captured is actually mirrored...ie upside down on the logical screen.
What has happened is that the command has captured the reflection of
the screen part. Thats the 'mirror' image, now lets try the rippling
water effect. Add these lines to the above routine.
15 logic=back
80 screen swap : wait vbl
90 goto 60
Note it is important that you make sure theres enough pixel lines for
the whole captured picture part or the command will squash it up to
make it fit......PHEW!!!....glad thats over with.
WASH scr,x1,y1,x2,y2
This is another version of CLS....the only difference to the WIPE
command is that its used to clear only part of the screen between co-
ordinates x1,y1,x2,y2. Note X co-ordinates are in steps of 16 pixels.
BLIT scr1,x1,y1,x2,y2,scr2,x3,y3
BLIT is a new faster version of screen copy. Those of you who have
used SKOPY from the MISTY extension will already be familer with this
command as the parameters are the same. X1,Y1,X2,Y2 are the co-
ordinates of the captured block of SCR1 and X3,Y3 are the co-
ordinates of SCR2 to place it on. Again all X co-ordinates must be in
steps of sixteen pixels.
EXAMPLE
10 key off : hide on : mode 0
20 rem Put a picture in bank 5
30 blit start(5),0,50,200,100,logic,32,100
Note that like screen copy, BLIT will copy a square block onto screen
so if you are placing it over a picture than you will see the
background of the picture you captured.
M BLIT scr1,x1,y1,x2,y2,logic,x3,y3
This is just like BLIT, only it merges the captured block on screen.
It works like SCREEN$ but does'nt need to store the captured block in
a varible first. Useful for placing part of a picture over another.
Well thats it for this month, why not play around with the commands
and see what happens.....
Next month........the Palette Commands.
Posted: 22 May 2018 18:26
The following articles never made it to MEGA DISCZINE as we never did issue 5.. but thankfully the article live on untouched since 1995...
MISSING LINK TUTORIAL PART FIVE
Here we are again folks, the mysteries of Missing Link explained by
little old me. We're onto part five now and I still have'nt seen any
games written with this extension so why not?
This month we have a look at the palette commands.
P=palt(PAL_ADDRESS)
palsplit MODE,PAL_ADDRESS,Y,YNUM,PAL_SPLIT
floodpal COLOUR
B=brightest(PAL_ADDRESS)
Lets look at these commands in turn.
P=palt(PAL_ADDRESS)
The PALT command is simular to the GET PALETTE command only it will
capture the palette from an MBK file or back such as pictures,
sprites, bobs, joeys, tiles, blocks, etc. It can be used instead of
the routine that normaly gets the palette from the sprite bank.
It seems that the command says set a varible (P) to the palette you
want STOS to take on but not so. Using this command as its written
will work just like GET PALETTE only this version will not get the
palette from a normal screen. Lets say we wanted to get the palette
from the sprite bank, we would use
P=palt(start(1))
The varible can be anyone you want, ignore the number it holds. As we
can see, the command sets the STOS default palette to the one in the
sprite bank so we can display the sprite on screens in its own
colours. PAL_ADDRESS is as you can guess, the address of the palette
to get. It can be either a screen or a memory bank.
palspilt MODE,PAL_ADDRESS,Y,YNUM,PAL_SPLIT
To the artist, the ST can be a little annoying as it can only display
sixteen colours on the screen at the same time. But with this command
we can have a few different palettes on the screen at any one time.
The command works by quickly spliting a number of palettes, in other
words, switching between them so fast it looks like theres more than
sixteen colours on screen at once. The only thing about it is that
you can only have one different palette on any same part of the
screen. Look at this example.
10 key off : curs off : flash off : hide : mode 0
20 reserve as screen 5 : load"pic.pi1",5
30 load"sprites.mbk"
40 get palette(5) : SP=palt(start(1))
50 screen copy 5,0,0,319,50 to 0,0
60 sprite 1,100,100,1
70 palsplit 1,SP,100,199,2
80 wait key : palsplit 0,0,0,0,0
The trouble with this command as far as I've found, is that you can
only display one normal picture with one palette. But you can display
an mbk files or banks in completely different palettes on screen at
the same time. Lets look at the commands parameters.
MODE: Turns the command on and off....set to nought if off and set to
one to activate it.
PAL_ADDRESS: The address of the palette to grab, which can be any
screen or a bank, if its a bank then use the start command.
Y: Which scanline to start from. In order to display so many palettes
the command draws lines across the screen, these lines are actually
the pixel lines we mentioned last month with the reflect command and
we can see this lines going along the screen on an old film. If you
wanted to start the pixel lines drawing from the top then we would
set Y to nought.
YNUM: How many lines to draw down the screen from Y. For a full
screen we would set this to 199, the length of the screen.
PAL_SPLIT: How many palette changes to do. If you had part of a
screen at the top of the screen with one palette and a sprite at the
bottom half of the screen with another then we have two different
palettes on screen at once, so PAL_SPLIT would be two.
In the above routine we loaded a picture into bank five then loaded
some sprites which go straight into bank one. We then put the top
half of the picture on the top half off the screen then we place the
sprite in the bottom half. We then use palspilt to flick in-between
the two palettes. Note that both parts of the screen each use a
different palette. So if we move the sprite to the top half of the
screen over the picture then we will see that the sprite takes the
pallete of the picture.
So we can have one palette from a screen but loads from any mbk bank
with sprites, bobs, joeys, tiles, etc. After GET PALETTE we can use
the palt command as many times as we like.
floodpal COLOUR
This is an easy one.....it allows you to choose a colour from the
present palette and change all the other colours to that one. So if
COLOUR was set to nought and that colour was black then all the other
colours in the palette would become black.
Another easy one, it just simply finds the brightest colour in your
palette, useful if you had a game where each picture had a different
palette and you wanted the text to always printnin a bright colour.
EXAMPLE:
10 load"picture",5
20 B=brightest(start(5))
30 pen B : print"Pen ";B;" is the brightest colour."
Thats it for this month.....next month, the FILE commands.
Posted: 22 May 2018 18:27
MISSING LINK TUTORIAL PART SIX
BY DEANO
Welcome to another part of the missing link tutorial. This month we
are going to look at the FILE commands.
L=dload(FILE_ADDR,ADDR,START,LENGTH)
L=dsave(FILE_ADDR,ADDR,START,LENGTH)
R=file length(FILE_ADDR)
bank load FILE_ADDR,ADDR,NUMBER
bank copy BANK1,BANK2,NUMBER
R=bank length(FILE_ADDR,NUMBER)
R=bank size(BANK,NUMBER)
Lets look at each one in turn.
The DLOAD command is a new LOAD command. It has features other than
LOAD such as allowing you to choose how many bytes of a file you wish
to load. The parameters are.....FILE_ADDR, which is the address of a
variable containing the name of a file on disk, for example.
F$="sprites.mbk"+chr(0)
The next parameter is ADDR which tells DLOAD where you want to load
the file....either a screen, or memory bank.
DLOAD allows you to only load part of a file if you so wish and
therefore the START and END varibles hold the byte to start loading
from and the byte to stop loading at. Lets say we wanted to load a
screen into a bank. We would bear in mind that a screen is 32032
bytes long so the end of this file is 32032...the length. Look at
this example program which will help to make this clearer.
10 key off : flash off : curs off : hide on : mode 0
20 F$="pic.pi1"+chr$(0)
30 L=dload (varptr(F$),physic,0,32032)
So first we are setting the varible to hold the name of the picture
file.....note the CHR$(0), this is needed by the command in order to
read the string. We then use the VARPTR command to tell DLOAD the
address of the file name so it can load it onto the physic screen
starting at byte 0 and stopping at byte 32032 in the picture file.
The L variable just holds the number of the bytes read.
The DLOAD command will not load a normal file from disk, it needs to
load a file saved in a special format. This needs the next command.
L=dsave(FILE_ADDR,ADDR,START,END)
The DSAVE command is used to save a file that can be read by DLOAD.
The parameters are the same as DLOAD only it saves the file. The good
point of these two commands is that no-one else can load these
specially saved files and therefore they can't use your files in
their own programs. Heres a routine that will save a screen for use
with the DLOAD command.
10 key off : hide on : curs off : flash off : mode 0
20 F$="PIC.PI1": load F$
30 rem Save picture in special format
40 L=dsave (varptr(F$),physic,0,32032)
50 end
This screen can now be loaded with the DLOAD command.
R=real length(FILE_ADDR)
This command just returns the unpacked length of a pack file. R will
equal the original length of the file before it was packed if it was
packed. If it was'nt packed then R would equal nought.
10 F$="PIC.PI1"+chr$(0)
20 R=real length(varptr(F$))
30 if R<>0 then print"File not packed." else print"The original size
of the file was ";R;" bytes."
bank load FILE_ADDR,BANK,NUMBER
This command allows you to load a file from a large file full of
files. In other words you can use store ten MBK files together in one
bank and just take the one you want out of the bank when you need it.
This is known as a file bank. A file bank is a collection of MBK or
binary files stored together. This will give you a tidy disk with all
the data files stored in one big one instead of loads of files
scattered around the disk.
In order to create one of these banks we have to use the MAKEBANK
program which is on the missing link disk in BAS format. Load and run
it and you'll see various options. If you use the add file option you
can choose a MBK or binary file to add to the file bank. Lets say you
wanted to have a file bank with three MBK pictures you would click on
ADD FILE with the mouse then choose a MBK picture. The program will
then load it into a file bank. Choose this option again to load more
MBK pictures into the bank. You could also use the ADD DIRECTORY
option to load a folder of MBK pictures......just click on the folder
and then return to load all the pictures into the file bank. When
you've finished click on SAVE FBANK to save the file bank.
Lets say the bank had three MBK pictures in it and we wanted to load
the first one from it.....heres the routine.
20 rem Reserve a bank the size of the first picture
30 reserve as data 5,12000
40 rem Load picture one into bank five
50 F$="pictures.bnk"+chr$(0): bank load varptr(F$),start(5),0
60 unpack 5
In a file bank, the file numbers range from nought to the number of
files in the bank. In the bank the picture numbers are moved back one
place so picture 1 would be picture 0, picture 2 would be picture 1
etc......so FILE_ADDR holds the address of the file banks name, BANK
is the memory bank to load it into and NUMBER is the file number to
load.
Supposed you made a file bank of twenty MBK pictures for use in an
adventure game. You could fix the game to load extra files and call
them when you need them.....for example if the game was loaded on an
ST with enough memory to hold all the pictures in memory and call
each one from a bank instead of disk. On a one meg version of the
game you could load the screens like this.
10 key off : hide : flash off : curs off : mode 0
20 rem Reserve bank five to the size of the file bank
30 reserve as work 5,40000
40 bload "pics.bnk",start(5)
50 rem Put first picture on screen
60 reserve as data 6,2580 : bank copy start(5),start(6),0
70 unpack 6
So BANK1 is the address of the file bank, BANK2 is the address of the
bank you've copied the picture into and NUMBER is the number of the
picture to copy ranging from 0 to the number of pics in the bank. In
this example we must use BLOAD instead of BANK LOAD.
Simply returns the length of file number NUMBER in FILE_ADDR. Useful
for finding out the length of the file in the bank so you can reserve
a bank for it. R equals the size of file NUMBER in FILE_ADDR.
10 F$="pics.bnk"+chr$(0)
20 R=bank length(varptr(F$),1)
30 reserve as data 5,R
40 print"Picture 1 is ";R;" bytes long."
R=bank size(ADR,NUMBER)
The last command checks the length of a file in a file bank on disk
but this command checks for the length of a file in a file bank in
memory. ADR is the bank containing the file bank and NUMBER is the
number of the file you want to check.
10 R=bank size(start(5),0)
20 print "Picture 1 is ";R;" bytes long."
Well thats it for this month....next month we shall be looking at the
sound commands......till next month........cheerio.
Deano
MISSING LINK TUTORIAL PART SEVEN
TUTORIAL BY DEANO OF SILLY SOFTWARE
Hello again STOSSERS, well, its another part of the link tutorial with
yours truly. In fact it looks like an easy month for me this time cos
i'm on the sound commands and theres only four.
Right lets get started, heres a list of the sound commands.
digiplay MODE,ADDR,SIZE or SAMPLE NUMBER,FREQ,LOOP
samsign ADDR,SIZE
R=musauto(ADDR,NUMBER,SIZE)
musplay ADDR,NUM,OFFSET
Music is the spice of life, it has a beat. Like the throb of pulse,
the beat of an heart, the ache of a scab. Lets see the first command.
digiplay MODE, ADDR, SIZE or SAMPLE NUMBER, FREQ, LOOP
The digiplay command allows you to play a sample. Unlike the STOS
maestro extension the digiplay takes up less processor time giving
your game more speed. Heres what each parameter means...
MODE: Bit pointless this one, it just turns the command on and off,
if its set to one then its on, if its off its set to nought. So you
pass MODE as nought then.....the command is ignored. Might as well
keep it set to one.
ADDR: The address of the raw sample. It can be a memory bank or even
a screen. Note if its in a bank then you must use the start command.
SIZE: The actual size of the sample in bytes. You can find out the
size by listing a directory which gives file sizes. Note this can
also be a sample number, more on this later.
FREQ: The playback speed of the sample between 3-25 Khz.
LOOP: if you want to play a sample once then set this to nought. If
you want the sample to keep playing then set it to one.
The sample must be loaded with the bload command in order for
digiplay to understand it. Here is an example that plays a sample
3000 bytes long in a loop from bank five at speed 10.
10 reserve as work 5,3000 : bload"sample.sam",5
20 digiplay 1,start(5),3000,10,1
30 wait key
40 digiplay 0,0,0,0,0
Using line 40 will stop the sample playing in a mind numbling loop.
This example will play one raw sample. But with Maestro we have the
ability to hold a few samples in a bank and play one like this
samplay 2 : rem plays sample two
This is possible with digiplay, load up the MAKE program and use it
to make a digibank. To do this, just load your samples in one after
the other then choose the save digibank option. You can load up to 50
samples in any one bank. Now to load and play it....
10 reserve as work 5,30000 : bload"sambank.mbk",5
20 digiplay 1,start(5),2,10,1
This is why the third varible has two different meanings. If its more
than 50 then the command assumes you want to play a raw sample. But
if its less than 50 then its assumes you want to play a sample from a
digibank held in a memory bank. Note that unlike maestro the sample
number starts from nought....so sample 1 would become sample 0,
sample 2 would become sample 1 etc....the above example plays sample
three from the digibank in memory bank five.
samsign ADDR,SIZE
I don't really know much about signed and unsigned samples only that
sometimes a sample will sound disorted when played with digiplay. The
samsign will sign the sample if its unsigned or visa versa.
Example
samsign start(5),3000
digiplay 1,start(5),3000,10,0
So ADDR is the address of the sample you wish to sign or unsign
depending on its status. And SIZE is the length of the sample.
R=musauto (ADDR,NUMBER,SIZE)
A lot of people, including myself can't stand the music created with
the STOS music accessory. Instead we use other chip music such as mad
max music. There are various music creator programs around such as
the Megatiser which allow you to create your own xbios chip tunes.
The musauto command will automaticaly play one of twenty one
different kinds of chip music. The parameters are
ADDR: The address of the music, usually a bank
NUMBER: The musauto command checks for the music to see how many
tunes are in it. Some mad max music can have two tunes stored
together like a stacked bank. Pass this parameter as the number of
the music you want to play starting from one.
SIZE: The length of the music.
The command works by looking at the offset of the music and setting
itself up to play that kind of music. Example.....
reserve as work 10,5000 : bload"madmax.mus",10
R=musauto(start(10),1,5000)
This plays mad max music on interrupt. Note how theres no setting it
to the offset of mad max music as the command works out what music
type it is. To stop the music playing just use....
R=musauto(start(5),0,5000)
Passing NUMBER as 0 will stop the music. There is a list of what
tunes musauto will play in the link doc.
musplay ADDR, NUMBER, OFFSET
Althought musauto can play up to 21 kinds of music, there will be the
odd tune it does'nt recognise because it can't work out the offset
number that stands it playing. Musplay will play other kinds of chip
music if you know the offset.
musplay start(5),1,1
Mad Max music has an offset number of one. So the example plays tune
one of mad max music.
Well thats it for another month.....next month, the joystick
commands.
Posted: 22 May 2018 18:28
MISSING LINK TUTORIAL PART 8
This month we are going to look at the joystick commands. Again another
easy month for me as theres not much to say about them. Heres the
commands.
D=P JOY(N)
P STOP
P ON
P UP(N)
P DOWN(N)
P LEFT(N)
P RIGHT(N)
The joystick commands in missing link are just the same as the default
STOS ones only they have a couple of advantages. First off we have a
command called.........P STOP
This is useful if you want to stop STOS reading the joystick in a loop
until a certain time. What it does is actually turn off the joystick(s)
so you can have a loop like this.
10 repeat
20 if p up(1)=true then y=y-2
30 if J=1 then p stop else p on
40 until p fire(1)
So in a normal listing using commands like JUP and JDOWN you would have
to have a variable telling STOS to ignore the lines that check for the
joystick where all you have to do here is to turn the joystick off. So
to look at this command again the format is
P STOP (Turns off the joystick ports)
Before you can use these joystick commands you have to turn them off.
P ON
So you can use P ON to activate the ports to use these joysticks and
P STOP to turn them off.
Another advantage of these commands is to allow you to read both ports.
You may know that you can actually have two joysticks connected to your
ST. One in the joystick port (port 1) which is the second port and the
mouse port (port 0) which is the first one. Of course if you check for
a joystick in the mouse port then that means you can't use the mouse.
Lets look at the other commands in more detail.
P UP(n)
This is just like the JUP command in STOS except that it has an extra
parameter. The parameter N is the number of the port you want to check.
Lets see this example.
10 p on : rem FIRST TURN THE PORTS ON
20 repeat
30 if p up(1) then y1=y1-4
40 if p up(0) then y0=y0-4
50 until inkey$=" "
60 p stop
In this loop we have two variables called Y0 and Y1 which hold the Y
co-ordinates of two sprites on screen. Line 30 checks to see if the
joystick in port one (joystick port) has been pushed up and if so, take
four away from the Y1 variable. Line 40 does the same, only for port
nought (mouse port). When the space bar is pressed the joysticks are
turned off.
To explain it all. Each of these commands are exactly the same as the
joystick commands only that they allow you to check the joysticks in
both ports rather than just the normal port one. Heres some examples.
if p down(0) then y0=y0+4 : rem Check if first joystick pulled down
if p left(0) then x0=x0-4 : rem Check if first joystick pushed left
if p right(0) then x0=x0+4 : rem Check if first joystick pushed right
if p up(0) then y0=y0-4 : rem Check if first joystick pushed up
if p fire(0) then F=1 : rem Check if fire button pressed
Put these lines in a loop and it allows you to check if the joystick in
port nought (the mouse port) has been accessed. Changing the noughts
to ones allows you to simply check the joystick port (port one). Note
the P FIRE command, this allows you to check if the fire buttons been
pressed.
Note how these commands are listed at the start as....
D=j up(n)
When the joystick is moved, the varible D equals one of two values.
0 : rem joystick has'nt been touched.
1 : rem Joystick has been moved.
So D or whatever variable you wish to use will either equal one if the
joystick has just been moved and nought if it has'nt. One more command
to explain then I'll give you an example of them all working together.
D=P JOY(n)
This allows you to check if the joystick as been moved like the JOY
command in STOS. D equals nought if its left alone and 1 if its been
moved.
Finally, an example of the commands working together.
5 F0=p fire(0) : F1=p fire(1) :rem Varibles for fire buttons
10 X1=40 : X2=40 : Y1=60 : Y2=60 : P ON : rem Set up variables and turn
on.
20 REPEAT
30 U0=p up(0) : D0=p down(0) : L0=p left(0) : R0=p right(0) :
rem Variables for joystick in port nought (mouse port)
40 U1=p up(0) : D1=p down(1) : L1=p left(1) : R1=p right(1) : rem
Variables for joytick in port 1 (joystick port).
50 A=p joy(0) : B=p joy(1) : rem Check if joysticks moving or still
60 if U0=1 then Y1=Y1-4 : rem Joystick 0 pushed up
70 if D0=1 then Y1=Y1+4 : rem Joystick 0 pulled down
80 if L0=1 then X1=X1-4 : rem Joystick 0 pushed left
90 if R0=1 then X1=X1+4 : rem Joystick 0 pushed right
100 if U1=1 then Y2=Y2-4 : rem Joystick 1 pushed up
110 if D1=1 then Y2=Y2+4 : rem Joystick 1 pulled down
120 if L1=1 then X2=X2-4 : rem Joystick 1 pushed left
130 if R1=1 then X2=X2+4 : rem Joystick 1 pushed right
140 if A=0 then home : print"Joystick 0 is not being moved"
150 if B=0 then locate 0,1 : print"Joystick 1 is not being moved"
160 sprite 1,X1,Y1,1 : wait vbl : sprite 2,X2,Y2,2 : wait vbl
170 until F0=1 or F2=1
The above routine will allow you to use both joysticks to move two
sprites at the same time. It also lets you know if the joysticks are
being used. And finally the last line ends the routine if one of the
fire buttons are pressed on either joystick.
Next month.......the miscellaneous commands.
MISSING LINK TUTORIAL- PART ERRM
As I said last month, the link tutorial has finished for those of you
who haven't registered. Upon registration you receive a third part of
the extension which covers not only new commands, but improvements to
existing ones. What I will do here is explain some of the new commands
in this extension, starting with.....
MANY BOB
The many bob command, as it says, will put many bobs on the screen. Its
much faster then using the normal bob command to put more than one bob
on screen. Like the normal bob command, there is a version of the
command to set a clipping zone for the many bobs, which is.....
many bob X1,Y1,X2,Y2,0,0,0,0,0,1
All those noughts don't mean anything as yet, I think they were put
there in case they could be used in a future update.
The next command actually draws the bobs.......
many bob SCR,ADR,IMADR,XADR,YADR,STADR,XOFF,YOFF,NUM,0
Confused? Well actually its not as bad as it looks. Lets go step by
step through each varible.
SCR:- The screen where the bobs are being displayed. This can be back,
physic, or logic.
ADR:- This is the bank containing the bobs (bob bank).
IMADR:- This is a pointer to an array holding the image numbers of each bob.
XADR:- This is a pointer to an array holding the X co-ordinates of each bob.
YADR:- This is a pointer to an array holding the Y co-ordinates of each bob.
STADR:- An array of numbers for each bob. If the number is one then the bob
is displayed, otherwise if nought it is'nt.
XOFF: A varible containing how many X pixels to move a bob.
YOFF: A varible containing how many Y pixels to move a bob.
NUM:- Number of bobs to put on screen.
Lets try and display, animate, and move three bobs at once.
20 dim IMAGE(3),XBOB(3),YBOB(3),STATUS(3)
Now lets set up the arrays. First the image numbers for each bob.
30 IMAGE(1)=0 : IMAGE(2)=1 : IMAGE(3)=2
Now, the X co-ordinates of each bob.
40 XBOB(1)=16 : XBOB(2)=32 : XBOB(3)=48
Same with the Y co-ordinates.
50 YBOB(1)=20 : YBOB(2)=30 : YBOB(3)=40
Now the status of each bob, (1) means the bob is displayed, and (2) means it
is'nt displayed.
60 STATUS(1)=1 : STATUS(2)=1 : STATUS(3)=1
Now lets display them on screen......
70 many bob logic,start(4),varptr(IMAGE(0)),varptr(XBOB(0)),varptr(YBOB(0))
,varptr(STATUS(0)),X,Y,3,0
Run this program and you'll see three bobs displayed on screen, all with
different image numbers and co-ordinates. Now change the contents of status
two to contain 0 instead of one by amending line 60.
Run the program, and you'll see the middle bob has gone. This is because
we've told the program not to display that one. This is useful for getting
rid of an alien thats been shot, just change its status to 0.
Animating the bobs is easy, just set the image numbers to the right frames
and just go back to the line, example....
100 many bob logic, start(1), varptr(IMAGE(0)) etc....
110 wait 10: IMAGE(1)=4 : IMAGE(2)=8 : IMAGE(3)=12 :GOTO 100
Moving is a bit strange, you have to set the bob to move in the other
direction you want it to. For example, this line
120 if jright then X=X-4
Will cause the bob to move right, and plusing will go left.
Try playing about with this command and you'll find it working for you
sooner or later. Errm, right, whats next.
MANY JOEY
This is just the same as many bob but its to draw loads of joeys. However
there is an extra array which holds the colour of each bob.
MANY BULLET
Draws loads of bullets on the screen, the same as many joey but the IMAGE
varible is not used.
H=hertz
This tells you what screen frequency your ST is running under, either 50, 60
or 70 for mono monitors. H holds the value.
SET HERTZ
Set the hertz rate to another frequency, 50 or 60, but 70 only on a mono
monitor, for example.
10 wait vbl : set hertz 60
A=mostly harmless (1,2,3,4,5)
This command don't have a useful use in programming, its just to get rid of
that annoying message that keeps popping up telling you to register. Try
typing this and saving it as autoexcu.bas, this will get rid of the message
every time you load STOS, a message says You got it, when its gone.
Right, thats the final end of the full missing link tutorial, I'm afraid
that due to deadlines I have'nt had time to work out all the commands so
thats why not all commands are covered.
Errm, right, I'm off.
Deano
Posted: 22 May 2018 18:29
Missing link tutorial part 10
By Deano of Silly Software
This month we look at the miscellaneous commands.
I=depack(ADDRESS)
D=compstate
relocate PROG_ADDRESS
R=boundary (N)
R=overlap (x1,y1,x2,y2,wid1,hg1,wd2,hg2)
reboot 0
Right, the first command.
The DEPACK command does as it says. It depacks a data file. In other words
it allows you to unpack or un-compress a data file. It works with various
packers including Atomik 3.5 and Ice Pack 2.4. The format is.
L=depack (ADR)
ADR can either be a screen or memory bank. L holds the length in bytes of
the file size and will equal nought if the file is'nt packed.
Example
10 reserve as work 5,free-10000: load"music.mod",5
20 L=depack(start(5))
30 if L=0 then print"File is not packed.":stop
40 if L<>0 then print"The file size is";L
When you pack a data file, always reserve your bank to the orignal size of
the file before it was packed because the command unpacks the file on top of
itself. It works well with MODS and chip music such as mad max.
D=compstate
This will return either one or nought depending on the state of your
program. If you run it from within STOS basic, ie, interpreter mode it will
equal 0. But if the listing is compiled it will equal one. Its main use is
for checking if your program is compiled. The advantage is that because the
compiler speeds varibles up (adding, subtracting, etc), its needed to set
the program to run at certain speeds so it does'nt run too fast when
complied. Take this listing for example.
10 if compstate=0 then NUMBER=1000
20 if compstate=1 then NUMBER=3000
30 repeat
40 dec NUMBER : home : print NUMBER
50 until NUMBER=0
The use of compstate in this listing means that the varible NUMBER will take
the same amount of time to count down in either interpreter mode or compiled
mode. For this to happen we have to make the varible an higher number if the
program is complied or it will count down much faster than we need.
relocate PROG_ADDR
Normal, when you load a machine code program into STOS, you can only load it
into a memory bank otherwise the CALL command won't work. The relocate
command sets up CALL to call the routine from something over than a bank so
you can run it from a screen address if you want.
Example
10 bload"SPEED.PRG",back
20 relocate back
30 call back
Its inportant in this case to bload it rather than normal load.
R=boundary (N)
Most of you will know by now that the ST has a screen problem. Parts of the
screen have to be copied on a 16 pixel boundary. In other words, graphics
have to be screen copied across the screen in a step of 16 pixels.
Example
screen copy 5,16,30 to physic,32,30
So X co-ordinates have to be in steps of 16....(0,16,32,48,64 etc).
So if we wanted to take a number and print the nearest 16 pixel step we use
this command. Take this listing.
10 X=11
20 N=boundary (X)
30 print"The nearest 16 pixel boundary is ";N
So the command has rounded the value of X to the nearest step which is
sixteen, because 11 is the nearest to 16 than 0 is. Try changing X to other
numbers and see what happens. For example, if X=25 then N would equal 32
because 25 is nearer to 32 than 16. N is the rounded up figure.
R=overlap (x1,y1,x2,y2,wd1,hg1,wd2,hg2)
Overlap is a colision detection command. It allows you to check if part of
the screen collides with another. It is useful to check if a bullet or a
sprite has reached a certain part of the screen.
X1 and Y1 are the top left hand co-ordinates of the first part of the screen
you want to check, X2 and Y2 are the top left hand corners of the second
part of screen to check, WD1 and HD1 are the width and height of the first
part of the screen and WD2 and HG2 are the second part.
So lets say we wanted to check if a sprite had entered the top left hand
corner of the screen.
10 XSP=x sprite(1) : YSP=y sprite(1)
20 A=overlap (XSP,YSP,0,0,16,16,16,16)
30 if A then boom : stop
40 if jleft then XSP=XSP-4
50 if jright then XSP=XSP+4
60 if jup then YSP=YSP-4
70 if jdown then YSP=YSP+4
80 sprite 1,XSP,YSP,1 : wait vbl
90 goto 10
So first the varibles XSP and YSP hold the x and y co-ordinates of the
sprite and this is entered in OVERLAP as the top left hand co-ordinates of
the first block to check...ie: the top left hand corner of the sprite.
We're checking the top left hand corner of the screen for the sprite
entering it so the co-ordinates are 0,0 the top left hand corner of the
second part (collsion block). Next we have the size of the sprite in pixels
which is 16 by 16 pixels. And finally the size of the on screen block which
is the same size (16 by 16 pixels). When the sprite enters this invisible
block then A equals other than nought and a collsion is detected then the
program stops.
If you're using sprites then its important that the hot spot is on the top
left hand corner of the sprite unless your using bobs then the hot spot is
always in that place.
reboot 0
This command preforms a cold boot. In other words it will reset the ST and
clears it completely. It acts like you've just turned the ST off. If you use
reboot 0 then it gives you a choice whever to go ahead or not. If you want
to skip this then put $ABCD instead of nought.
Thats the end of the first part of the link tutorial. The second part is
only of use to you if you registered, because the registration package comes
with an extra extension with added and improved commands. For those of you
who have'nt registered then I'm afraid that the LINK tutorial has finished
for you.
For registered users, I'll see you next month.
Deano
