peters wrote: 10 Jul 2025 12:35
There are 2 cards in.
If anything touches either of them then they will cause problems. Either not detected or ram slot errors.
So definitely a mechanical problem somewhere.
- poor pressure from the SIMM bracket spring (is it a metal spring-clip or plastic clip holding the SIMM in position?)
- dirty/oxidised contacts on the memory or the socket (are the SIMMs and socket both gold plated, or is one or other tinned?)
- dry joints on the SIMM socket pins.
- cracked trace on the main board under the SIMM (not very likely unless some strong impact)
What implement and chemical should they be cleaned with ?
The most basic tool would be a new, clean toothbrush with firm bristles and some 70% or better IPA/alcohol. (If it's less than 99% make sure the board has been well dried for a good period before powering it back on, to make sure no water remains).
For the SIMM stick contacts you can use paper card soaked in some alcohol to rub the contacts clean. If the pads are gold this should be easy. If they are tinned, they could be dull and you'll see a lot of grey residue come off when cleaning. They should be shiny if possible or at least the residue should reduce the more you clean it.
Alcohol isn't always very effective at cleaning on its own and it doesn't itself remove stuff from the surface, just dilutes it and washes it around, then dries again - so you need to make an effort to wash the contacts off with some alcohol and e.g. absorbent thing like a cotton bud or paper towel.
There are other things you can use but will be more expensive and/or more trouble to clean up and adds some risk for other e.g. plastic components nearby.
Real contact cleaner for electronics is better for this. In some cases, I use WD40 (common gas-oil lubricant, close to petroleum) which can dissolve some things alcohol won't touch (like dried flux). I would only use that here if you have it handy and don't have any IPA/alcohol. (It stinks and leaves residue which isn't nice to handle but will clean very well - it can dissolve some plastics so watch out).
I'm not sure I should try to resolder them.
This step only requires heating the pins with fresh solder or flux. If nothing else works you could find someone near you who can do it.
