Page 1 of 20
Fixing my Milan 040 (or not) blog
Posted: 22 Jun 2025 12:29
Thought I would start a new blog for this.
Its been sat on my shelf for like 20 years. I managed to get a Veloce STE and some other bits from a guy who was selling his stuff years ago. The Milan apparently was working until he dropped a screwdriver on the motherboard. As to if this is true or not...
I did find one of the simm sockets looked iffy. Changed it for the wrong angled type :( I need to send my graphics cards to
@PhilC to try in his Raven soon. IIRC I had 4 but only 2 worked and think it was
@Zogging Hell I sent them to. But it was such a long time ago and the conversation long lost.
I think the clock gen circuit was working last time I poked around but that's all I remember. My first point of call is to figure out where ROM is and see if there's any signs of life.
It will likely be a very slow backburner project. At this point I don't even know how many simms it needs too boot or what slots etc? .. So if anyone can shed some light on how to get a default setup done it would really help as i have no idea.
- IMG_3388.JPG (267.21 KiB) Viewed 1859 times
Re: Fixing my Milan 040 (or not) blog
Posted: 22 Jun 2025 13:12
by PhilC
@exxos they are ISA cards aren't they?
Posted: 22 Jun 2025 13:28
by dml
Is that a greenish corrody splodge on the battery?
Posted: 22 Jun 2025 13:42
PhilC wrote: 22 Jun 2025 13:12
Think so yes..
Posted: 22 Jun 2025 13:43
dml wrote: 22 Jun 2025 13:28
Probably yes.. The board may even to go for a bath at some point.
Posted: 22 Jun 2025 16:14
Found this site which looks to have some good info..
https://www.der-ingo.de/en/milanhelp/index.html
Posted: 22 Jun 2025 19:08
Posted: 22 Jun 2025 19:13
by dml
The CPU gets hot super quick? I don't remember that being a thing on the Afterburner 040 or even CT60. It takes some time for them to heat up.
That looks like a 25MHz part - not sure if that makes a difference but I still would expect it to warm up fairly slowly but get hot after a few mins.
...also, I think you mentioned earlier the cause was a screwdriver falling into the board while it was on. So you should probably be expecting an IC got shorted to +VCC, or there are mashed pins where the screwdriver landed. Or maybe a damaged trace but it's easier to damage the pins on the topside.
Posted: 22 Jun 2025 19:27
by agranlund
That’s a really cool board, going to be interesting to follow this blog. I hope you do get it running :)
Posted: 22 Jun 2025 19:28
dml wrote: 22 Jun 2025 19:13
It starts heating up form power up.
27c cold
30 seconds 32c
60 seconds 37c
1.5mins 40c
2mins 43c
hotspot 53c neat the simm sockets.
IIRC I bought a second 040 CPU years ago but no change. At this point I dont even know if the CPU works. I will have to try and find my other 040.. but after 20 years ... :D
Yep the default speed AFAIK is 25MH on the Milan.
Yeah, I don't see anything bashed anywhere. But when I first looked at it (20+ years ago) the outside simm socket looked damaged, hence why I changed it. So I assume the screwdriver hit that simm socket.
I checked and flash CE/OE goes low after pressing reset, stays low after that. So its pretty dead :(
