Page 1 of 2
FreeMiNT OS-Distribution
Posted: 09 Dec 2025 16:17
by kohli79
Hello, I downloaded this FreeMiNT OS distribution onto a CF card.
https://github.com/rootadm79/freemint_os_distro
Everything runs smoothly with a standard 14 MB Falcon/C-Lab MKI.
However, as soon as I activate the DFB1X, the system crashes right at the start.
With 11 bombs, sometimes even with 3 or 4... I have already contacted the uploaders, but they didn't know the solution either.
Blitter is deactivated and memory protection is also turned off.
Everything is fine under TOS 4.04 with DFB1X and there are no problems.
Does anyone have any idea where the error lies? Thank you.
Best regards, Uwe
- FreeMiNT Boot error.png (1.88 MiB) Viewed 1618 times
- FreeMiNT Bootmenü.png (2.16 MiB) Viewed 1618 times
Re: FreeMiNT OS-Distribution
Posted: 09 Dec 2025 16:26
I cannot offer anything constructive but I tried FreeMiNT about a year ago and it just scrolled loads of errors. IIRC it was also moaning for some reason the drive was write protected (when it wasn't) . I gave up in the end.
https://www.exxosforum.co.uk/forum/view ... 10#p118376
You might want to not use MAPROM though as that does "interesting things" which it might not like.
Was not aware of that image either.. Looks good. Wish they had a files download rather than a image though!
Posted: 09 Dec 2025 17:02
by kohli79
exxos wrote: 09 Dec 2025 16:26
Okay. Thanks for the information anyway.
Nothing has changed in the setup, it's just as it was installed.
The link for the download is this one. ;)
https://ns.mpsoftware.cz/filehosting/card.img
I'll test it a little more...
Posted: 09 Dec 2025 18:25
by Steve
I have a feeling it's something to do with HD Driver and Maprom. HD Driver has an option to load into fast RAM, it also has options for IDE blitter acceleration. Try making sure all these options are turned off in the configuration app. Better still, you could try EmuTOS instead of TOS 4.04 which will bypass HD Driver entirely and also won't require Maprom.
Posted: 09 Dec 2025 18:46
by kohli79
Everything should actually be deactivated. I'll check again tomorrow, as I'm at my girlfriend's place now and she doesn't have a Falcon. :lol:
I'll try to boot without maprom.
I can also test EmuTOS then.
Posted: 09 Dec 2025 23:45
by mikro
Interesting. Just to be on the safe side, you could also try downloading and running
https://tho-otto.de/snapshots/freemint/ ... clones.zip instead. I don't expect to behave differently but you never know.
I don't know what exactly MAPROM does but yeah, sounds like a good idea to disable it first.
There's also one open issue with 030 + TT RAM:
https://github.com/freemint/freemint/issues/308 but this seems to be related to CT2. I still have to look into it.
Posted: 10 Dec 2025 11:24
by Badwolf
Other things to try to narrow it down:
* Remove all FPUs (motherboard FPU should be removed anyway if you have DFB1X installed)
* Disable the mint.prg in the AUTO folder and instead copy MINT000.PRG directly there (yes, 000).
Posted: 10 Dec 2025 13:09
by kohli79
Oh man, it's working. Yes, it was HDDriver. :oops:
Although I'm sure I hadn't activated the options, they were switched on. (IDE and Blitter acceleration) No idea ...
I knew they had to be off. Otherwise, everything is as installed, MapROM isn't causing any problems either.
The version from Thorsten Otto is also working. It even boots a little faster.
Thanks for the help ...
Posted: 10 Dec 2025 14:55
So is the BLITTER turned off by default in the image? And your saying it turned the option on by itself somehow?
Posted: 10 Dec 2025 15:29
by kohli79
exxos wrote: 10 Dec 2025 14:55
The blitter was not enabled when I checked after the first start in SI.CPX.
The Blitter Acceleration/IDE option in HDDriver was somehow re-enabled.
I have no idea why, or maybe I'm already senile and don't remember. :lol:
I had actually disabled this.
Now that everything is running, the blitter option in SI.CPX is no longer selectable.
