Page 1 of 1
C100501-001 REV.1.0
Posted: 27 Apr 2018 05:46
by Atarian Computing
http://www.atari-computermuseum.de/520st.htm
- c100501-001-10.JPG (642.27 KiB) Viewed 12863 times
Re: C100501-001 REV.1.0
Posted: 30 Aug 2021 18:44
by KLund1
I have this board, and I think the Shifter and DMA labels are switched.
FYI
Posted: 30 Aug 2021 21:34
KLund1 wrote: 30 Aug 2021 18:44
Yes it looks wrong.
Posted: 30 Aug 2021 22:53
by stephen_usher
Yeah, why would the Shifter be next to the WD1772? Makes no sense.
Posted: 30 Aug 2021 23:17
by PaulJ
Take your ohm meter out and measure from pin 11 of the 1771 to pin 30 on the shifter and dma chip. When you get ~0 ohms that's the dma chip. The other device will have a significantly higher resistance reading.
Posted: 12 May 2022 06:21
by olivier.jan
I have the same motherboard in my Mega 2 and I keep wondering why U32 and U35 are not populated. Why bother having the sockets if these chips are not installed and why are these chips required on all other STs but not this one?
Posted: 12 May 2022 10:25
olivier.jan wrote: 12 May 2022 06:21
From factory ?! Assume someone removed them at some point ? Looks to be the 244 buffers ?
Posted: 12 May 2022 10:27
by olivier.jan
The machine still had the seal when I got it and the picture posted here shows the same sockets without the chips, so I suspect it's from Factory.
Moreover, the Mega ST 2 without this chips is still working perfectly :shock:
Posted: 12 May 2022 10:29
olivier.jan wrote: 12 May 2022 10:27
:WTF:
Can you post images top and bottom of that board ?
Posted: 12 May 2022 20:25
by olivier.jan
Ok, I should stay away from my beer pump for a while…. I opened the machine and the chips are there which makes much more sense. Sorry for the confusion. :headbang:
