Broken reset circuit / 555?
Posted: 30 Jul 2025 12:47
Certain Atari fan nudged me into opening my *second* broken Falcon tower (with a CT2B installed) so while doing that, I decided to finally check its shape, just in case that's easily repairable so I wont be losing too much time with the first one.
The first symptoms were quite similar to viewtopic.php?t=7810 -- no DE on Videl, nothing on monitor, nothing's happening in both Normal and Turbo mode but I do see /AS and friends being alive, even activating /ROM3 (but that's that, it didn't make it to the diagnostic cart's serial output). So I'm like what are the odds that on both of them is the Videl dead, right?
Fortunately I occurred to me to start from the beginning, i.e. measure /AS vs /RESET and imagine my surprise when seeing this on U1's (555) pin 3:
Every 2us or so there's a new reset pulse. Huh.
This is propagated everywhere, most notable the CPU and Videl, so no wonder that Videl doesn't output anything.
For starters I would like to ensure one thing: seeing this on the 555's output pin (and U11's input pin) means that there's no way this is caused by a Falcon IC, right? Because if XRESET (U11's pin 2) was LOW due to some IC, it couldn't reach the 555 due to U11 being an inverter which goes only one way, correct?
