Page 1 of 1
Updating firmware with a Pi
Posted: 22 Dec 2024 11:15
by Brunty
Hello!
I've still got the original firmware on my TF1260 and I've just seen that people have used a Raspberry Pi to update it. On having a bit of a search I see that the method uses "Wiringpi" which is now unavailable. Is there another solution? I've got a Zero 2 ready to go!
Thanks
David
Re: Updating firmware with a Pi
Posted: 22 Dec 2024 11:22
by Steve
Is it Xilinx? If so, I followed this guide to flash the Xilinx on the tf530:
https://linuxjedi.co.uk/programming-xil ... pberry-pi/
Posted: 22 Dec 2024 14:55
by supaduper
Brunty wrote: 22 Dec 2024 11:15
Hello!
Thanks
David
Here is my 8gb Raspberry pi image that you can flash to a SD card , it has all the XC3sprog on it ready to use,just put your jeds in Downloads folder and just open a terminal and run the commands as it says in the howto by LINUXjedi in the link in an earlier post
If it asks for a password use ` Backlash1 `
https://mega.nz/file/EwYERaJK#J1JPFBySS ... --ofo5Mvns
Posted: 22 Dec 2024 15:47
by Brunty
supaduper wrote: 22 Dec 2024 14:55
Hello!
Thanks
David
That is absolutely brilliant, thankyou!
