ST536 -- how to check if working/what's broken?
Posted: 05 Dec 2024 23:10
Hi,
I am one lucky owner of ST536 in Mega ST. And, I apparently commited some kind of stupidity, resulting in booster not working _at all_.
Background: some weeks ago I acquired old pak68 card, sold as untested. Just base board, without RAM, only 68020, FPU and oscillator for 16MHz clock (http://amiga.resource.cx/exp/pak). After some small fixes (replacing damaged connector pins), I decided to test it in my Mega ST -- replaced ST536 with this card, and actually booted my Mega ST, from emutos/128KB on cartridge -- needed because of long stack frame on 68020.
All great, I was very excited with my first 'repair', but after I tried to switch pak68 to higher frequency (two jumpers on board, selecting onboard oscillator), card no longer booted in _any_ configuration. Screen is yellowish with slight thrash (or white in other MegaST), nothing happens.
But real tragedy was when I temporarily gave up PAK and returned to ST536: apparently I wasn't carefull enough, and switching cards I managed to bend and eventualy break couple of ST536 DIP64 connector pins :(. I replaced both DIP connector strips with new ones, checked board for any additional physcal damage, even tested conductivity for most of connector signals (especially broken ones) -- I dont see any additional damage. BUT ST536 also doesn't boot -- yellowish slightly thrashed screen, nothing happens. Checked ST536 in my other Mega ST -- same. I have to assume that I somehow broke this card. Single day, two cards trashed :(
Said MegaST works fine with 68000 of course...
I still hope that I didn't actually terminally damage this ST536 treasure. So, how do I proceed? How can I check what is wrong with card? Is there a possibility that reflashing can help? How do I do it? Or, how do I check for other possibilities of repair? Do you have any suggestions?
Regards and thanks in advance,
Przemek Szeremiota
Przemek Szeremiota
