Page 1 of 1
ST/F/M MEGA ST 4MB MEMORY UPGRADE [0035]
Posted: 27 Sep 2024 00:49
by rawbe
Hello- I would like to purchase the ST/F/M MEGA ST 4MB MEMORY UPGRADE [0035] upgrade for my Atari 1040 STF. I see I need to order the ribbons cable separately. I found those in the shop no problem. My question is, do I need to order the Shifter board? If so, where is the Shifter board in the shop? I cannot find it. Also, what is the Shifter board?
Thank you for your help,
Robbie
Re: ST/F/M MEGA ST 4MB MEMORY UPGRADE [0035]
Posted: 27 Sep 2024 09:45
The answer is in the store notes:
Screenshot 2024-09-27 at 09.45.09.png (91 KiB) Viewed 673 times
So in answer to your question, no it isn't, it's a separate item.
Posted: 27 Sep 2024 10:10
by elterwater
The note is incorrect, the item number for the kit is #0214, not #0124.
The PCB shifter board and the built shifter board are both straight after the main kit itself in the shop.
Posted: 27 Sep 2024 10:32
elterwater wrote: 27 Sep 2024 10:10 The note is incorrect, the item number for the kit is #0214, not #0124.
Good spot. @exxos can you fix please?
As before though, the item needs to be purchased separately.
Posted: 27 Sep 2024 13:20
by rawbe
Thank you for the reply! I found all parts needed in the shop.
Posted: 27 Sep 2024 14:06
rubber_jonnie wrote: 27 Sep 2024 10:32
Feking typos! sorry!! thanks!!! Updated :)
