Page 1 of 2
ISA-PicoMEM
Posted: 27 Jun 2024 13:19
by Icky
I came across this ISA card using a Pico Raspberry PI. Its gives a lot of features in one ISA card. Am looking at this for my Amstrad PC1640.
Features:
  • Integrated Bootable ROM: Enables in-system configuration and booting from any vintage system with Option ROM support.
    Press "S" at boot to configure and select disk images, memory settings, and more.
  • MicroSD Card Reader: Allows storage of multiple floppy and hard drive images (disk .img files).
  • RAM : Upgrade conventional memory and add UMB (128kb with 0 wait state other from external PSRAM)
  • EMS Memory: Supports 4MB of EMS memory with current drivers.
  • USB Support: Provides USB mouse and joystick support via a Micro USB OTG hub.
  • NE2000 Network Emulation: Currently in beta, this feature works through the RP2040's integrated Wi-Fi module.
    Note that no external antenna is supported, which may reduce signal strength in some computer cases.
  • Firmware Updates: Easily update the firmware by copying a single file to the PicoMEM via a Micro USB cable.
    The card will automatically reboot and run the updated firmware.
  • ROM Addressing: Cards are preset to ROM address 0xD000, allowing coexistence with XTIDE BIOS on existing CF adapters.
https://github.com/FreddyVRetro/ISA-PicoMEM
Re: ISA-PicoMEM
Posted: 27 Jun 2024 13:42
by Cyprian
nice project,
Am I correct that ISA has 8bit slot?
Re: ISA-PicoMEM
Posted: 27 Jun 2024 14:08
by Icky
Cyprian wrote: 27 Jun 2024 13:42 nice project,
There are 16-bit and 8-bit versions of ISA cards. This one is an 8-bit card.
Re: ISA-PicoMEM
Posted: 01 Jul 2024 15:10
by Icky
Ordered one from https://shop.flamelily.co.uk/picomem
Will report back when I get time to try it out.
Re: ISA-PicoMEM
Posted: 02 Jul 2024 09:21
by HomeLate
I have one, bought from the creator (Freddy).
I only tested it briefly in a Sinclair PC200 and it works great. You can copy any DOS disk image on a SD-Card and the image is available as a bootable drive on the PC200.
Freddy is designing a low profile PCB for in the PC200. For those who don't know, the Sinclair PC200 has two ISA 8-bit slots. Due to the design of the PC200, only low profile 8-bit ISA cards fit if you want to have to top lid closed.
Re: ISA-PicoMEM
Posted: 02 Apr 2025 10:51
I just got one of these for my Amstrad PPC512 (Now 640), will get it tested soon.
Re: ISA-PicoMEM
Posted: 02 Apr 2025 11:12
by HigashiJun
Nice find !
Re: ISA-PicoMEM
Posted: 02 Apr 2025 12:03
OK, so wow. PicoMem has just obliterated the XT-IDE. I now have 3 working hard drives in a matter of minutes.
I'm very impressed indeed.
Re: ISA-PicoMEM
Posted: 02 Apr 2025 13:01
by Hellraiseruk
Adrians digital basement did a review on it a while back, looks like a fantastic piece of kit...
JD
Re: ISA-PicoMEM
Posted: 02 Apr 2025 13:19
Hellraiseruk wrote: 02 Apr 2025 13:01 Adrians digital basement did a review on it a while back, looks like a fantastic piece of kit...
JD
It really is, it lets you create HDD images and have up to 4 drives. It does so much, totally amazing.
